Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: File boot and 3D problem |
| Print at Sep 29, 2026, 2:52:58 PM | |
| Posted by Marbel at Nov 11, 2017, 6:28:52 PM |
File boot and 3D problem Hi, when I try to boot a file it is necessary a lot of minutes to complete the boot. There is an icon like a clock over every object. At boot terminated the render 3D do not work properly, it go at step (very slow). I update at 5.6 version and also Java is updated. Since some week ago all was OK. My notebook is HP Pavilion I5 with 8 Gb ram. Thanks for help Marco |
| Posted by bdfd at Nov 12, 2017, 12:11:51 PM |
Re: File boot and 3D problem Hi, OS ? Size of your file ? zipped or not ? Try to delete heavy objects... ![]() ---------------------------------------- Evil progresses when good people do nothing! --- SH3D 7.1 and nothing else - W11 64b in 4K |
| Posted by Marbel at Nov 12, 2017, 1:49:21 PM |
Re: File boot and 3D problem Hi, Windows 10 home edition. File size 100 MB "zipped or not" ? what means Where I can see the size of objects? Thanks |
| Posted by bdfd at Nov 12, 2017, 2:19:40 PM |
Re: File boot and 3D problem Hi, OK.Windows 10 home edition. File size 100 MB "zipped or not" ? what means "save as" and "save and compress" What did you do ? Where I can see the size of objects? Right click on the list in lower left frame and choose "display column" and "size model"... ![]() ---------------------------------------- Evil progresses when good people do nothing! --- SH3D 7.1 and nothing else - W11 64b in 4K |
| Posted by Marbel at Nov 12, 2017, 4:16:21 PM |
Re: File boot and 3D problem Hi, I save only "save as". What is (apart save MB) the difference if you open an use a compressed o not compressed file? And, what about my problem ? Do you know a possible solution Thanks |
| Posted by bdfd at Nov 12, 2017, 6:24:23 PM |
Re: File boot and 3D problem I think that W10 home, 8 Go and 100 MB are not enough for sh3d and java... ![]() ---------------------------------------- Evil progresses when good people do nothing! --- SH3D 7.1 and nothing else - W11 64b in 4K |
| Posted by Puybaret at Nov 13, 2017, 12:09:08 AM |
Re: File boot and 3D problem Marbel, you should try to increase the max memory used by the program, unless you use the 32 bit version of Sweet Home 3D (see in the About dialog of Sweet Home 3D). ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Marbel at Nov 13, 2017, 1:52:48 AM |
Re: File boot and 3D problem Hi, I am using: Sweet Home 3D ® Versione 5.6 Java Web Start Versione Java 1.8.0_151 / 32 bit / 0,6 GB max Versione Java 3D 1.6.0. Is a 64 bit version for windows?? If yes, how much can I increase the max memory for the program (I have 6 Gb ram). Thanks |
| Posted by Puybaret at Nov 13, 2017, 3:44:21 PM |
Re: File boot and 3D problem If your system is 64 bit, try the installer version which will install Sweet Home 3D 64 bit. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Marbel at Nov 14, 2017, 12:19:26 AM |
Re: File boot and 3D problem OK, thanks |
Current timezone is GMT Sep 29, 2026, 2:52:58 PM |
