Sweet Home 3D Forum » List all forums » » Forum: New versions » » » Thread: Sweet Home 3D 5.6 |
| Print at Oct 11, 2026, 4:21:14 AM |
| Posted by Puybaret at Oct 25, 2017, 9:17:05 PM |
Sweet Home 3D 5.6 For your information, I released Sweet Home 3D 5.6 tonight. It's a maintenance release that fixes some bugs and regressions listed here. Many thanks to the users who reported them ![]() ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by gargantua at Oct 29, 2017, 6:37:17 PM |
Re: Sweet Home 3D 5.6 hello, I have an issue with my update. I have a file made in the 5.5, that I cant open entirely with the 5.6. Nothing appear on my floorplan screen and the grid disapeared too. Can you help me please, and sorry for my bad english. |
| Posted by Puybaret at Oct 29, 2017, 9:33:38 PM |
Re: Sweet Home 3D 5.6 Try to reinstall Sweet Home 3D 5.5 and check if you can open your file. If it's not the case, that must be an other issue. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Ceciliabr at Oct 30, 2017, 7:26:45 PM |
Re: Sweet Home 3D 5.6 Version 5.5, September 6, 2017 Made doors and windows always cut out the both sides of the walls to which they are added. When opening a project after upgrading to 5.6 from 5.2, I noticed a side effect of this enhancement: We can no longer make custom cut-outs in walls, like making a niche - or, as in my case; create a basin for a kitchen sink – since any insert will cut clean thru the entire wall. ![]() The illustration shows the old project ( 5.2 ) opened in v 5.6. The old cut-outs are not affected, but it's impossible to make new ones. Just mentioning - in case you were unaware... cec |
| Posted by bdfd at Nov 1, 2017, 1:21:55 PM |
Re: Sweet Home 3D 5.6 Hi, Today, windows 10 fall creators update : downloaded and installed SH3D 5.6 : tested OK... ![]() ---------------------------------------- Evil progresses when good people do nothing! --- SH3D 7.1 and nothing else - W11 64b in 4K |
| Posted by Puybaret at Nov 2, 2017, 2:11:43 PM |
Re: Sweet Home 3D 5.6 As explained here: Doors and windows now always cut out both sides of straight or round walls when they are parallel or tangent to them [...] To avoid changes in your existing designed plans, this feature will work only for newly added doors and windows, except for service hatches that will continue to dig walls if they partly cover the wall thickness. This is exactly what you experienced, the niches you created with transparent boxes with Sweet Home 3D 5.2 are still here when you open your file in Sweet Home 3D 5.6, but the new ones created from the catalog (not the ones copied - pasted from the existing file) always cut out the both sides of walls. If you don't want this behavior, use a service hatch setting its material to transparent. You may still use the transparent box like in previous versions only if you include it in a sh3f file and set its doorOrWindowWallCutOutOnBothSides# property to false in the PluginFurnitureCatalog.properties file, like in the DiggingInvisibleBox.sh3f file attached to this post. ---------------------------------------- ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by GWatson at Jan 12, 2018, 5:03:21 AM |
Re: Sweet Home 3D 5.6 5.6 now takes over an hour to render approx 70 pieces of furniture. Same on 5.5. There has been several Win 10 updates since I last used Sweet Home. Any ideas on how to fix the VERY slow rendering of the furniture? Thanks |
| Posted by Puybaret at Jan 12, 2018, 8:39:13 AM |
Re: Sweet Home 3D 5.6 If by "render", you mean creating a photo at one of the two best quality levels, nothing was recently changed in the program that could slow down this operation. Maybe you added many lights, chose a larger size for the image or you could also check if increasing the max memory used by Sweet Home 3D will improve the rendering. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by GWatson at Jan 13, 2018, 4:23:41 AM |
Re: Sweet Home 3D 5.6 Hi Puybaret, Thanks for the reply. I mean when I load an existing plan and the placed furniture images are just rectangles. Slowly over like an hour, the correct furniture images load. How do I attach a screenshot as your image attach requires a link? Thanks |
| Posted by GWatson at Jan 13, 2018, 5:47:06 AM |
Re: Sweet Home 3D 5.6![]() |
Current timezone is GMT Oct 11, 2026, 4:21:14 AM |
