Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Isometric View Tweak |
| Print at Sep 26, 2026, 7:50:08 PM | View all posts in this thread on one page |
| Posted by jdab at Aug 24, 2017, 5:10:40 PM |
Isometric View Tweak Hi, As I'm trying to get Isometric views from my models, I've come to try specifics settings with the "Virtual Visit" 3D View : - body angle : 225° - head's : 35° - Field of view : 10° (lowest possible) With the appropriate distance from the subject, the result is good but not perfect. Verticals ligns are ... not exactly verticals, as I understand perspective rules are mistreated here. Though, would it be possible to lower the camera's angle ever more to get the proper result ? Or is there another solution ? Looking forward to hear from you, Regards, Jdab |
| Posted by Puybaret at Aug 24, 2017, 6:32:16 PM |
Re: Isometric View Tweak Try a more recent version of Sweet Home 3D or even the version 5.5 beta, you'll be able to use a 1° field of view... ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by jdab at Aug 24, 2017, 7:45:05 PM |
Re: Isometric View Tweak Thank you very much Emmanuel, it helps a lot 👍 Field of views is still locked at 2° and result's not perfect, but I can deal with it. Correct me if I'm wrong, but the narrow field of view acts as a zoom, doesn't it ? Had to take a 114 m. step back and 65 m. of height to capture a 2,8 m. cube. I'll have to work my geometry out to get same results more easily. Others improvements, like objet rotation, are much appreciated too !! Thanks again |
| Posted by Puybaret at Aug 24, 2017, 8:38:57 PM |
Re: Isometric View Tweak Sorry for the wrong answer. I remember having programmed some tests with a minimum of 1°, but for some reasons, I finally kept 2° as a minimum value. the narrow field of view acts as a zoom, doesn't it ? Yes, it's the same. Zooming actually changes the field of view of a lens.---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 26, 2026, 7:50:08 PM |
