Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: create room with exact size impossible |
| Print at Aug 21, 2026, 4:11:16 PM | |
| Posted by Ash2k at Apr 9, 2017, 11:22:37 PM |
create room with exact size impossible Hi, I am trying to create a room which has accurate measures, but it seems, I can only generate measures on 2 mm exact measure instead of 1 mm. My room is 1555mm long but I can only create one with 1554mm or 1556mm lenght, is there any way to make it exactly 1555 mm long ? |
| Posted by bdfd at Apr 10, 2017, 8:56:34 AM |
Re: create room with exact size impossible Hi, Hi,I am trying to create a room which has accurate measures, but it seems, I can only generate measures on 2 mm exact measure instead of 1 mm. My room is 1555mm long but I can only create one with 1554mm or 1556mm lenght, is there any way to make it exactly 1555 mm long ? Did you try to reduce the thickness of the wall of 2 mm ? (1 mmm for each side). ![]() ---------------------------------------- Evil progresses when good people do nothing! --- SH3D 7.1 and nothing else - W11 64b in 4K |
| Posted by Ash2k at Apr 10, 2017, 10:06:14 AM |
Re: create room with exact size impossible Hi, where can I do such a thing ? I did not even know, there is a wall, if I create a room, I think creating a wall is something diffrent. |
| Posted by VeroniQ at Apr 10, 2017, 12:38:02 PM |
Re: create room with exact size impossible Did you read the user's guide ? |
| Posted by Ash2k at Apr 10, 2017, 5:42:29 PM |
Re: create room with exact size impossible So I have to read all to find out, how to create a room, with a size of 1 mm more ? Look it is a simple question, I am not unexperienced with other pretty similar tools. I only not understand, how to make my room 1555 mm long that is all. If this program is not able to do so, then it is bullshit and I download another one, simple as my question is. My room has no walls yet, because it does not show the exact size I want it to have. |
| Posted by bdfd at Apr 10, 2017, 6:15:19 PM |
Re: create room with exact size impossible So I have to read all to find out, how to create a room, with a size of 1 mm more ? Your brain is strange !Look it is a simple question, I am not unexperienced with other pretty similar tools. I only not understand, how to make my room 1555 mm long that is all. If this program is not able to do so, then it is bullshit and I download another one, simple as my question is. My room has no walls yet, because it does not show the exact size I want it to have. A room without wall is a terrace... But I'm agree with you about the distances 1554 or 1556 are only available, not 1555 mm. So tell us why 1 mm is important for you ? Wait after Manu's answer... ![]() ---------------------------------------- Evil progresses when good people do nothing! --- SH3D 7.1 and nothing else - W11 64b in 4K |
| Posted by Ash2k at Apr 10, 2017, 6:33:06 PM |
Re: create room with exact size impossible The room, and wall are even 2 diffrent symbols in this program. Why 1 mm is important ? Sry ? This is a 3D design program, isn't it ? It is used to make plans of rooms, and if I can't realize my room in it, it simply does not fulfill it's purpose at all. If that room is 1mm longer or shorter, it will not fit into the other 3D Environment. This program looks pretty good, but it is useless, I am sry, all your hard work for nothing. It's only coold for kids. Thx for "help" cu and good luck |
| Posted by hansmex at Apr 11, 2017, 10:02:36 AM |
Re: create room with exact size impossible Possibility 1 To draw EXACT lengths, use this feature: - select the Walls button - click for first point of wall - hit Enter - a small window pops up where you can enter the exact length of the wall, angle and thickness - make walls 1 mm longer than needed and set wall thickness to 1 mm Your walls will have your exact dimensions. Possibility 2 If you have the AdvancedEdit plug-in installed, you could also draw a room, then EditPoints to set the exact room dimensions. - select the Room button - draw a room that has the approximate size and shape you need - edit the room points using Plan --> Edit Points - select the Walls button - double click on the room: walls will be drawn around your room Good luck with this "kids program". Maybe you should study the user guide and help files before drawing conclusions? Hans My motto in life: If you don't know how to use a program: blame the program, not yourself! ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by lordthistle at Nov 24, 2021, 6:48:22 AM |
Re: create room with exact size impossible I agree with the original poster that this functionality is a little too counter-intuitive (by far the most "difficult" among the 3D design programs I have used). I have exactly the same difficulties. I have installed the advanced edit plugin, but I cannot find the "plan -> edit points" menu item. However, long menus are not fully visible on the screen and they do not scroll so may be the item is not visible. |
| Posted by Puybaret at Nov 24, 2021, 11:13:46 AM |
Re: create room with exact size impossible You could try to create rooms first as explained in this video. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by UbuntuBirdy at Nov 24, 2021, 6:31:03 PM |
Re: create room with exact size impossible If you don't know how to use a program: blame the program, not yourself! I like your sense of humor, Hans! But I know the frustration of being too lazy to learn the functions of the free software... Still, this shouldn't be an excuse for such behavior - it's just arrogant and disrespectful! ---------------------------------------- Pascal SH3D 6.6 / Ubuntu 22.04 (Mainline-Kernel) / Radeon RX580 / Ryzen 7 5800x |
| Posted by dorin at Nov 24, 2021, 8:01:36 PM |
Re: create room with exact size impossible Maybe this How to draw precisely -mini tip could help. PS Don't miss Note 2 ![]() PS2 If you don't need walls you could delete after create room. ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
Current timezone is GMT Aug 21, 2026, 4:11:16 PM |
