Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: 3d View suddenly impossibly slow |
| Print at Sep 29, 2026, 12:56:41 PM |
| Posted by ybon at Nov 18, 2017, 10:46:42 AM |
Re: 3d View suddenly impossibly slow Quick follow-up: - I've tested SweetHome3D on a fresh Ubuntu 17.10 install, and it frozen when I started drawing a wall (tried twice) ![]() - back on my main computer running arch, I've tested SH3D version from 4.6 to 5.4, here is the summary * 4.6: responsiveness OK, HDPi support NOK (click is shifted, icons are two small, drawing grid is too small) * 5.0: responsiveness OK, HDPi support NOK (same) * 5.1: responsiveness OK, HDPi support NOK (same) * 5.2: responsiveness OK, HDPi support NOK (same) * 5.3: responsiveness NOK (oops), HDPi support OK (yay :)) * 5.4: responsiveness NOK, HDPi support NOK (click is shifted, icons are two small, drawing grid is too small) * 5.5: responsiveness NOK, HDPi support NOK (same) * 5.5.2: responsiveness NOK, HDPi support NOK (same) So, seems something is going on with 5.3 release. Given this release fixes the HDPi support (for me), it may be that the responsiveness issue is related. Strangely, starting from 5.4, HDPi support is broken again (for me), but the responsiveness isn't fixed. Sadly, from this quick investigation, I see that there is no release with both responsiveness and HDPi support for me. Any hint out from those new elements? Anything I can test out? Thanks :) |
| Posted by ybon at Nov 18, 2017, 11:19:06 AM |
Re: 3d View suddenly impossibly slow Tried to run 5.3 version without 3D view (adding -Dcom.eteks.sweethome3d.no3D=true argument), but the responsiveness issue is still present. Also tried to pass -Dcom.eteks.sweethome3d.resolutionScale=2 to version before 5.3, but it does not seem to apply. |
| Posted by ybon at Nov 18, 2017, 4:38:19 PM |
Re: 3d View suddenly impossibly slow OK, adding all those parameters, I can run 5.2 with HDPi support and a normal responsiveness: -Dcom.eteks.sweethome3d.resolutionScale=2 -Dswing.defaultlaf=javax.swing.plaf.metal.MetalLookAndFeel -Dswing.plaf.metal.controlFont=Dialog-12 -Dswing.plaf.metal.userFont=SansSerif-12 -Dswing.plaf.metal.systemFont=SansSerif-12 :) Still interested by a fix to be able to run the latest release though :) |
| Posted by LeenaM at Dec 13, 2017, 4:05:58 PM |
Re: 3d View suddenly impossibly slow Slowness that appeared suddenly is an issue here. What can an ordinary user do within the usual administrative tools for Windows and Java? I have Windows Home 10.0.16299 and Java Versin 8 Update 151 build 1.8.0_151-b12 |
| Posted by LeenaM at Dec 14, 2017, 2:06:03 PM |
Re: 3d View suddenly impossibly slow Seems to be working OK now, since yesterday! Have done/changed nothing. Happy to receive a comment or explication, though! |
| Posted by veverone at Feb 18, 2018, 4:08:44 PM |
Re: 3d View suddenly impossibly slowTo use these options, simply execute the installer in a cmd window followed by the options of your choice separated by spaces. For example: C:\SweetHome3D-5.5-windows.exe /j3d.version=1.5.2 /os.arch=x86I'm looking forward to reading your comments to be able to modify the FAQ accordingly. For me, Sweet home 3d was crashing right from the start with "fatal error (...) update your driver/directx". I tried this and it works wonderful! Anything else I tried doesn't work, but this worked, in that exact combination (tried it one without the other and was still crashing). My info: OS Name: Microsoft Windows 10 Pro |
| Posted by Puybaret at Mar 3, 2018, 3:48:59 PM |
Re: 3d View suddenly impossibly slow From a recent discussion with Java 3D maintainers, there seems to be a solution to run Sweet Home 3D under Windows 10 64 bit on old Intel processors with integrated graphics. If you continue to get the driver error at Sweet Home 3D launch in 64 bit, you should simply download https://communities.intel.com/servlet/JiveSer...80582/legacy-igpu-x64.zip unzip it and execute the install.cmd it contains. Please, try it and report how it worked for you. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Chucky2910 at Mar 6, 2018, 10:11:56 AM |
Re: 3d View suddenly impossibly slow Hi, have the same problem right now. Using Windows 10 on a Laptop with Intel HD Graphic 4000. The 3D view is laging as hell and i installed Java 3D after this it seem to befixed for around 15 Minutes. The 3D View worked nice but than lags again. If i load a saved project i can see that the models on the 2D view take much more time to load as before... I dont know what to do now. Have tried Puybaret tip with the legacy igpu thing but without any effect. |
| Posted by scanti81 at Mar 29, 2018, 5:25:37 PM |
Re: 3d View suddenly impossibly slow My company is developing an app base on Java3D as well. We found out that disabling double buffering on the 3D Canvas helped to resolve this problem. Hope this helps. |
| Posted by EmAlvin at Mar 31, 2018, 4:49:53 PM |
Re: 3d View suddenly impossibly slow That worked for mee too. I just added a slight modification due to the version number and ran from comd line: SweetHome3D-5.7-windows.exe /j3d.version=1.5.2 /os.arch=x86 in order to reinstall from scratch my new SH3D version. While my previous 5.7 plain installation did terribly slow down on 3D rendering, this installation mode competely fixed any issue. I operate on a laptop with Windows 10 home 64 bit and a 3 years old Intel core i7 cpu. I also noticed that after reintalling SH3D, it reserves just one third RAM than before. So, tx a lot! |
Current timezone is GMT Sep 29, 2026, 12:56:41 PM |
