Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: Objects with texture |
| Print at Sep 20, 2026, 3:11:00 PM | View all posts in this thread on one page |
| Posted by Gymnos at Feb 23, 2017, 5:49:17 AM |
Objects with textureI have made some furniture in "Sketchup" and some people in "Makehuman"but when I try and import them they loose their texture. I have tried various formats OBJ and DAE but the only difference is grey or clay colour. What have I done wrong. |
| Posted by hansmex at Feb 23, 2017, 10:41:08 AM |
Re: Objects with texture DAE and OBJ models come with a separate directory for the textures. If you move the model, you should move the directory as well so that the relative path stays the same. If you don't do that, the model will be white. H ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by picmau at May 11, 2018, 7:31:24 PM |
Re: Objects with texture @hansmex may you please help me explainig which are the step I have to do to "move the directory as well so that the relative path stays the same"? Sorry but I am rally not expert ![]() |
| Posted by picmau at May 15, 2018, 2:37:23 AM |
Re: Objects with texture Is there anyone can help me? |
| Posted by okh at May 15, 2018, 9:53:40 AM |
Re: Objects with texture The easiest, I guess, is not to move anything before using Import Furniture in SH3D. That is, import them from where you originally saved the DAE or OBJ files... If you need to move them, OBJ requires: xxx.obj (the .obj file itself) xxx.mtl (specifies the materials used) xyz.jpg / xzz.png (texture files referenced in the .mtl file) DAE requires: xxx.dae (the .dae file) and usually a directory with the same name (xxx or whatever) with texture files (.jpg/.png/.gif) So if you go to your export directory and select the above and move them together, it should work. ok |
| Posted by Puybaret at May 15, 2018, 10:42:57 AM |
Re: Objects with texture And to complete okh good suggestion, once imported in Sweet Home 3D, you can then move or even delete the downloaded files. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by bhoffman67 at Mar 8, 2022, 2:19:08 AM |
Re: Objects with texture ahhhh... xxx.MTL file <--- neato. Is there a MTL file corresponding to the texture/material files available directly from SH3D? |
| Posted by Puybaret at Mar 8, 2022, 3:35:23 PM |
Re: Objects with texture 3D View > Export to OBJ format menu item creates an OBJ file from the current home + a MTL file + images for the textures it needs. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 20, 2026, 3:11:00 PM |
