Print at Sep 20, 2026, 5:02:14 PM
Posted by Gymnos at Feb 23, 2017, 5:49:17 AM
sad   Objects with texture
I have made some furniture in "Sketchup" and some people in "Makehuman"but when I try and import them they loose their texture.
I have tried various formats OBJ and DAE but the only difference is grey or clay colour. What have I done wrong.
Posted by hansmex at Feb 23, 2017, 10:41:08 AM
Re: Objects with texture
DAE and OBJ models come with a separate directory for the textures. If you move the model, you should move the directory as well so that the relative path stays the same.
If you don't do that, the model will be white.
Posted by picmau at May 11, 2018, 7:31:24 PM
@hansmex may you please help me explainig which are the step I have to do to "move the directory as well so that the relative path stays the same"?
Sorry but I am rally not expert sad
Posted by picmau at May 15, 2018, 2:37:23 AM
Is there anyone can help me?
Posted by okh at May 15, 2018, 9:53:40 AM
The easiest, I guess, is not to move anything before using Import Furniture in SH3D. That is, import them from where you originally saved the DAE or OBJ files...
If you need to move them,
OBJ requires:
xxx.obj (the .obj file itself)
xxx.mtl (specifies the materials used)
xyz.jpg / xzz.png (texture files referenced in the .mtl file)
DAE requires:
xxx.dae (the .dae file)
and usually a directory with the same name (xxx or whatever) with texture files (.jpg/.png/.gif)
So if you go to your export directory and select the above and move them together, it should work.
Posted by Puybaret at May 15, 2018, 10:42:57 AM
And to complete okh good suggestion, once imported in Sweet Home 3D, you can then move or even delete the downloaded files.
Posted by bhoffman67 at Mar 8, 2022, 2:19:08 AM
ahhhh... xxx.MTL file <--- neato.
Is there a MTL file corresponding to the texture/material files available directly from SH3D?
Posted by Puybaret at Mar 8, 2022, 3:35:23 PM
3D View > Export to OBJ format menu item creates an OBJ file from the current home + a MTL file + images for the textures it needs.
