Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Change font size in dimension numbers |
| Print at Sep 6, 2026, 4:24:49 AM | |
| Posted by Jxdust at Jan 25, 2017, 10:35:07 AM |
Change font size in dimension numbers Hello everybody, Can you change the font size of the numbers in the dimension specification? In my plan, I can change the font size of the numbers of the area specification (Ctrl + Alt + K), but not the font size of the numbers in the dimension specification. And this is so small that you can hardly see it.. Greetings Jürgen |
| Posted by Puybaret at Jan 25, 2017, 7:59:00 PM |
Re: Change font size in dimension numbers That should be the same shortcut. Did you try Plan > Modify text size > Increase size menu item after selecting the dimension lines? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Anakowi at Oct 2, 2018, 3:17:25 PM |
Re: Change font size in dimension numbers I have a similar query... using MacOS I see the option in the PLAN menu and the keyboard shortcut is ^⌘+ BUT I'm not sure which keypress to use for "caret" the first symbol? |
| Posted by Puybaret at Oct 2, 2018, 8:24:42 PM |
Re: Change font size in dimension numbers Maybe you have an old keyboard, but on mine, the symbol ^ is written at the top the control key. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 6, 2026, 4:24:49 AM |
