Print at Sep 6, 2026, 4:16:08 AM View all posts in this thread on one page
Posted by aneng at Jan 18, 2017, 12:12:49 PM
Aerial view centred way off to the right ?
Hi. I've just installed SweetHome3D for the first time and I'm taking my first steps in using the program. However, I cannot seem to get the 3D Aerial view to be centred within its window. Whatever I draw appears all the way over to the right side in 3D view - very often cutting off half of my building as it is outside the window.
Is this a bug or am I doing something stupid ?!
Thanks !
e.g.
Posted by Puybaret at Jan 18, 2017, 10:55:30 PM
Re: Aerial view centred way off to the right ?
And how the 3D view behaves when you select 3D view > Virtual visit? Do you have the feeling that the 3D view match the location of the visitor drawn in the plan?
Posted by aneng at Jan 21, 2017, 9:25:27 PM
No. Selecting Virtual Visit makes the 3D image move to the correct perspective. Reselecting Aerial View makes the image move off to the right as my per original screenshot.
However - I have discovered that the problem is only there when the SweetHome3D window is maximised. If I draw when the application is *not* maximised, the 3D image appears in the correct position. Also, if the application IS maximised, I can correct the problem by right-clicking the 3D image window and choosing "Display in separate window".
One last thing - is it possible to make objects snap to each other or snap to grid ? I have a lot of trouble trying to make walls line-up correctly without snap.
Thanks !
