Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Aerial view centred way off to the right ? |
| Print at Sep 6, 2026, 4:25:01 AM | |
| Posted by aneng at Jan 18, 2017, 12:12:49 PM |
Aerial view centred way off to the right ? Hi. I've just installed SweetHome3D for the first time and I'm taking my first steps in using the program. However, I cannot seem to get the 3D Aerial view to be centred within its window. Whatever I draw appears all the way over to the right side in 3D view - very often cutting off half of my building as it is outside the window. Is this a bug or am I doing something stupid ?! Thanks ! e.g. ![]() |
| Posted by Puybaret at Jan 18, 2017, 10:55:30 PM |
Re: Aerial view centred way off to the right ? And how the 3D view behaves when you select 3D view > Virtual visit? Do you have the feeling that the 3D view match the location of the visitor drawn in the plan? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by aneng at Jan 21, 2017, 9:25:27 PM |
Re: Aerial view centred way off to the right ? No. Selecting Virtual Visit makes the 3D image move to the correct perspective. Reselecting Aerial View makes the image move off to the right as my per original screenshot. However - I have discovered that the problem is only there when the SweetHome3D window is maximised. If I draw when the application is *not* maximised, the 3D image appears in the correct position. Also, if the application IS maximised, I can correct the problem by right-clicking the 3D image window and choosing "Display in separate window". One last thing - is it possible to make objects snap to each other or snap to grid ? I have a lot of trouble trying to make walls line-up correctly without snap. Thanks ! |
Current timezone is GMT Sep 6, 2026, 4:25:01 AM |
