Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: when the program is reset |
| Print at Sep 20, 2026, 11:29:08 PM | |
| Posted by AngeloFolle at Oct 28, 2016, 3:21:23 PM |
when the program is reset Hello everyone, I’m using this program about 3 years and I have only one problem: at one point it blocks-turn off and RESET. And I mean that disappear all imported models. And it happened about a dozen times or maybe more. It just happens to me? maybe they have already spoken, but I don’t find the discussion on forum. Someone can help me understand what it is that I'm wrong? My Operating system is Windows 10, the program sweet home 3d 2016 (the last) . Thank you (translation italian-english by google) Salve a tutti, uso questo programma da circa 3 anni e ho un solo problema: a un certo punto si blocca-si spegne-si RESETTA. E intendo che scompaiono tutti i modelli importati. E mi è successo circa una decina di volte o forse di più. Succede solo a me? magari ne hanno già parlato ma non trovo la discussione. qualcuno può aiutarmi a capire cos'è che sbaglio? Grazie |
| Posted by Puybaret at Oct 28, 2016, 3:30:42 PM |
Re: when the program is reset Do you use the Online version or the installer version? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by AngeloFolle at Oct 31, 2016, 8:53:27 AM |
Re: when the program is reset installer version |
| Posted by Puybaret at Oct 31, 2016, 4:02:14 PM |
Re: when the program is reset Under Windows 10, imported furniture and textures are stored in the folder C:\Users\user\AppData\Roaming\eTeks\Sweet Home 3D where user is your login. Maybe you have a tool on your computer that cleans your data folder? Does it happen on a regular basis (every day, every week...)? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by AngeloFolle at Oct 31, 2016, 4:34:59 PM |
Re: when the program is reset i just use CCleaner Free (three times a week), but the cleanliness does not coincide with the occurrence of the reset. The program SH3D is reset about 6 months or 3. |
| Posted by AngeloFolle at Dec 26, 2018, 3:27:27 PM |
Re: when the program is reset For the record: the problem is not solved. I'm quite tired of this. please, I would like to know if someone has a solution. |
| Posted by Puybaret at Jan 8, 2019, 3:12:49 PM |
Re: when the program is reset Sorry, you shouldn't hope to recover data you lost 3 months ago. Did you check that the content of the folder C:\Users\user\AppData\Roaming\eTeks\Sweet Home 3D changes when you import some furniture? If it's the case, it means that Sweet Home 3D works correctly and the program doesn't remove any of the imported furniture unless you delete them from the catalog. Anyway, if you want to backup the imported furniture, you could also create some furniture libraries with the plug-in ExportToSH3F. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by AngeloFolle at Jan 14, 2019, 4:39:33 PM |
Re: when the program is reset Thanks, i will do in this way |
Current timezone is GMT Sep 20, 2026, 11:29:08 PM |
