Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Trouble installing plugins.. |
| Print at Sep 28, 2026, 3:21:00 PM | View all posts in this thread on one page |
| Posted by stevellion at Oct 21, 2016, 3:20:29 PM |
Trouble installing plugins.. I'm running on Ubuntu, every time I try to install a plugin I get the following error pop-up from sh3d. Running command: /usr/bin/sweethome3d ExportToHTML5-1.1.sh3p Getting "Can't import plug-in" pop up in dialogue box. I've also tried manually moving the extract into ~/.eteks/sweethome3d/plugins but it doesn't seem to recognise it. Thanks. |
| Posted by hansmex at Oct 21, 2016, 11:59:15 PM |
Re: Trouble installing plugins.. DO this - CTRL H (this shows hidden directories) - go to /.eteks/SweetHome/plugins (or something similar) - if "plugins" doesn't exist, create it - copy the plugin(s) to that directory - (re)start SH3D ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by stevellion at Oct 22, 2016, 1:18:40 AM |
Re: Trouble installing plugins.. Thanks hansmex.. I'd tried all that stuff already and copying into a new directory. In the end it was something really silly. Even though I was in the directory holding the sh3p file, I needed to specify explicitly the directory, not just relative. ie. /usr/bin/sweethome3d /home/joebloggs/downloads/plugin.sh3d It must be something in the script that uses it for install. |
| Posted by Puybaret at Oct 22, 2016, 1:33:53 AM |
Re: Trouble installing plugins.. Maybe the program doesn't have the rights to copy in the target directory. To be sure where this folder is, import a furniture library and if it works, search on your disk the furniture folder where it was copied. The plugins folder should be a sibling folder of that furniture folder. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 28, 2026, 3:21:00 PM |
