Print at Oct 6, 2026, 7:01:54 AM
Posted by bobbob601 at Aug 25, 2016, 9:57:32 AM
Fix output video
I'm rendering a video and it takes...weeks to do it even with a good machine because the soft does not seem to use GPU or the full RAM of my computer (32Go).
I ran a rendering which almost finished after 4 weeks but then I had to restart the computer and I lost everything. I found the "in progress" video in AppData, with a nonstreamable extension.
the file is "corrupted" because the index is missing and will be created at the end.
is it a way to fix the file ? I tried several "mov repair Tools" but none of them seems to know this format nor how to fix it.
Posted by Puybaret at Aug 25, 2016, 2:36:06 PM
Re: Fix output video
You were very patient, and unfortunately, I don't think the file can be repaired. sad
Note that using the GPU would require some big changes in the program and wouldn't probably improve that much the rendering speed if you have a good CPU. Please, see also the FAQ How can I speed up the rendering process in photo and video creation panes?
Posted by bobbob601 at Aug 25, 2016, 3:13:43 PM
Hi Emmanuel,
Thanks for the quick answer and no prob for the GPU, I know how it can be hard to implement. I also tried the FAQ advices but removing objets or lights is what I need and also why I need the good quality video.
I tried the "level 3" of quality to get this video (40h of computing) https://www.youtube.com/watch?v=ZFV9GIranjs&feature=youtu.be
But I don't like the fact that walls are shiny (maybe I can disable it somewhere) and also because it produce some artefacts.
Regarding the video, do you use a specific codec ? Maybe I can develop something which can recreate the video index from the frames ?
Posted by Puybaret at Aug 26, 2016, 10:49:39 AM
The tool that assembles JPEG images to video uses a Quicktime descriptor.
Posted by bobbob601 at Aug 26, 2016, 7:19:42 PM
Thanks. It seems that I'll have to install Eclipse afeter 15 years using visual studio :)
If I succeed to make Something clear, I'll share the source code with you in case it can be useful to someone else
Posted by Miker777 at Aug 29, 2016, 6:31:52 PM
applause   Re: Fix output video
Hi Bobbo
I thought both the house and the video were awesome, shhh, as for the technical help, no idea, i can barely create an image.
Again well done!
