Print at Sep 28, 2026, 6:07:49 AM
Posts: 19   Pages: 2   [ Previous Page | 1 2 ]
Posted by wannerb21 at Mar 27, 2017, 5:44:46 AM
shock   Re: Fatal error at starting : need to updated drivers opengl directX
I downloaded the program on a windows 7 ultimate (TRAVELING so use the old trusty laptop)
Worked fine and allowed me to save the 3D pictures and even allowed me to edit the 3D pics in the initial session. When I went to reopen them for a second session the fatal error message closed the program down.
I downloaded the drivers, but no luck. Seems strange that it all worked perfectly when the program was first installed.
Posted by bdfd at Mar 28, 2017, 8:04:48 AM
Can you verify the version of java ?
Posted by [email protected] at Aug 9, 2017, 11:09:34 AM
Is there any solution of this drivers problem???
Posted by Puybaret at Aug 10, 2017, 5:58:08 PM
Sorry but I fear there will be never a universal solution for drivers. Sometimes, a system update breaks something, sometimes a driver update breaks something else.
Posted by Nitemare at Aug 16, 2017, 1:08:08 PM
This is an old problem: http://www.sweethome3d.com/support/forum/viewthread_thread,6206
Posted by pooky2483 at Dec 11, 2019, 7:05:10 PM
Well, as of 11 Dec 2019 the problem still exists.
I'm running Kubuntu16.04LTS
OpenGL Version 3.0 Mesa 18.0.5
Posted by phpworm at Mar 6, 2020, 1:38:18 PM
I'm having the same issue as of 3 March 2020
Linux Mint 17
OpenGL version 4.5.0 NVIDIA 384.130
I can run the older version available through the package manager without any problems, but the downloaded current version tells me to update my drivers even though I'm using the recommended drivers.
Is there no solution for this?
Posted by phpworm at Mar 6, 2020, 3:04:02 PM
UPDATE: I feel pretty stupid but after running the file named "SweetHome3D-Java3D-1_5_2" instead of "SweetHome3D" it is working, and appears to be the current version. It was just the filename throwing me off.
Posted by mmanzur at Apr 8, 2020, 4:12:46 AM
smile   Re: Fatal error at starting : need to updated drivers opengl directX
Have the same problem in 64 bits version. I install the 32 bit versions and the problem has gone smile
