Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: Problems creating a light |
| Print at Aug 13, 2026, 10:01:35 PM | View all posts in this thread on one page |
| Posted by Finnithnel at Mar 20, 2016, 6:13:28 PM |
Problems creating a light Hi, I'm trying to create a model for the Ikea Knappa lamp : http://www.ikea.com/fr/fr/catalog/products/50070651/ I created a Knappa.sh3f archive containing the file : - PluginFurnitureCatalog.properties (code below) id#1=Knappaand the folder "models" containing 3 files : - knappa.obj (from blender) - knappa.png (rendered with blender) - knappa.mtl (containing code below) newmtl AmpouleMy main problem is that I'm unable to get a good render inside sweethome3d => When I use only 1 light source with 3.0 diameter, the lamp is rendered correctly (with shadows and so on) but the room get nearly no light (light is filtered by the lamp part) => When I "cheat" by adding another light source of 46 diameter (same as lamp size), then the room is correctly lighted, but the render of the lamp is awfull as it receive light from outside I tried using Tf 1.0 to not filter anything, then a low Ni to let the light get through the lamp, but no matter how I change the settings, the only visible result is when the "illum" parameter is changed; and the result differ but is still not good Any expert could help me to solve this ? |
| Posted by Finnithnel at Mar 30, 2016, 6:40:07 AM |
Re: Problems creating a light Well, it looks like there is no solution to this problem :s |
| Posted by Puybaret at Mar 31, 2016, 11:39:05 AM |
Re: Problems creating a light Sweet Home 3D doesn't fully support OBJ format, and Tf is simply ignored in the current version. Anyway, I think the missing factor is light reflection, not light transmission. Your solution with a small light located within the light structure and one a outside seems a good trade-off. Using a smaller value lightSourceColor value for the small light source should be better though. You could also try to compute an image with some light reflection, using Advanced settings of photo rendering plug-in described here. Setting globalIllumination with path value gives different results with only one source light placed at the center of the lamp but it takes much longer to compute with some noisy results. Double light source with default renderer setting One light source with path value for globalIllumination and 1 as diffusedBounces By the way, when you create a sh3f file from an other one like you probably did, you should at least remove or change its id found in the PluginFurnitureCatalog.properties file, otherwise it could mislead the auto update system in Sweet Home 3D with the updates of existing libraries. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Finnithnel at Mar 31, 2016, 12:45:06 PM |
Re: Problems creating a light Bonjour Emmanuel, Tout d'abord un grand merci pour ton logiciel qui est juste génial ! Et merci beaucoup d'avoir pris le temps de me répondre Le rendu que tu obtiens avec ce plugin semble très proche de la réalité, je vais donc suivre ton conseil Pour ce qui est des identifiants, je repars effectivement toujours de la même bibliothèque vide que j'édite pour chacun de mes modèles, sans savoir que cela poserait problème lors des mises à jours Ne sachant pas vraiment quels id sont dispos, si je supprime la ligne id comme tu le suggère, cela solutionnera le problème ? |
| Posted by Puybaret at Mar 31, 2016, 4:15:14 PM |
Re: Problems creating a light Dans ton cas, je pense que le mieux est de supprimer l'id en effet. Une bibliothèque sans id est ignorée du système de mise à jour. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Aug 13, 2026, 10:01:35 PM |
