Print at Aug 13, 2026, 10:57:52 PM
Posted by hansmex at Feb 13, 2016, 12:41:37 PM
Windows 10: importing libraries
Today I tried to import the updated furniture libraries.
After downloading I copied all files to C:\Users\Hans\AppData\Roaming\eTeks\Sweet Home 3D\furniture.
I restarted the program, then even restarted the computer, but to no avail: my libraries don't show up in SH3D.
What am I doing wrong?
Posted by okh at Feb 13, 2016, 2:19:52 PM
Re: Windows 10: importing libraries
I guess you have tried all this - but just in case:
It may be that Win uses another directory, for instance this: C:\Users\Hans\eTeks\Sweet Home 3D\furniture
Did you try Help-About-Libraries? Clicking an existing library (if any) should tell you which directory to use.
Assuming you have taken the libraries out of the .zip container so you have .sh3f files, did you try double-clicking them (provided file associations work) OR Furniture-Import Furniture Library?
As for what you are doing wrong, one possible conclusion could be "using Win 10" smile
Posted by okh at Feb 13, 2016, 2:33:48 PM
C:\Users\Hans\Application Data\eTeks\Sweet Home 3D\furniture
- or some in some of the other subdirectories under
Some of these directories are identical, pointing to each other - just have not bothered to figure out the logic of it all.
Posted by hansmex at Feb 13, 2016, 4:22:06 PM
Hola Ola,
Problem solved.
1 - The files were in the correct library.
2 - Seems the files were double-zipped. I unzipped the files after putting them in the correct library. Turns out I had to unzip them again. Now they show the *.sh3f extension and are recognized by SH3D.
3 - Thanks for the tip that clicking the library shows the directory.
4 - I hate W10 !!
Posted by okh at Feb 14, 2016, 10:46:50 AM
Good problem is solved, until the next appears... Meanwhile, how about a dual boot? Always worked very nicely for me in the past.
Posted by Vidium at Mar 13, 2016, 7:30:49 PM
[Moderated : please don't double post, moreover in a thread that doesn't match your issue]
