Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: How to set the different elevations at each corner of the ground level? |
| Print at Sep 10, 2026, 8:05:03 AM | View all posts in this thread on one page |
| Posted by maplelandhomes at Jan 28, 2016, 7:29:35 PM |
How to set the different elevations at each corner of the ground level? I am new to the sweet home 3d software. Currently, i am designing my house and the lot is sloppy. How can i set the different elevation at each corner? Example: Facing at the front of the house: 1.Corner left is 2 feet below the ground and 2.Corner right is 4 feet below the ground Facing at the back of the house: 3.Corner left is 3 feet below the ground 4.Corner right is 5 feet below the ground Thanks everyone in advance |
| Posted by okh at Jan 28, 2016, 8:06:43 PM |
Re: How to set the different elevations at each corner of the ground level? You probably need a workaround, if you look around the forum, you will find many threads discussing this, e.g. 4817 , 3335 , 6060 , 4450 - and then quite a few... Depending on what you want, triangles or other geometry may help. ok. |
Current timezone is GMT Sep 10, 2026, 8:05:03 AM |
