Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: how to connect walls? |
| Print at Sep 6, 2026, 8:48:41 AM | View all posts in this thread on one page |
| Posted by bartleby at Jan 19, 2016, 9:55:22 AM |
how to connect walls? if u want to make a corner (90 degrees) out of 2 single walls, after changing a plan, those 2 walls will not be perfectly connected like when u build this corner at once. is there a way to fix this? sometimes tricky in the 3d-view. maybe i should add a picture if am at home ;). |
| Posted by okh at Jan 19, 2016, 4:16:01 PM |
Re: how to connect walls? If you do not want to draw the wall again so it joins existing walls, the Advanced plan editing plug-in will let you join (connect) walls. Pay attention to wall direction (reverse if need be) and the order you select the walls you wish to connect. ok |
| Posted by bartleby at Jan 19, 2016, 8:01:20 PM |
Re: how to connect walls? again, thx. great program and that for free - must be really much work. i had problems with my houseproject being too big. with windows 7 i can make pictures in every quality without a problem, but with linux mint i have no chance to make pictures with better or best quality. worked in the beginning when project was smaller. maybe it will work again with ure "connect wall fix" - we will see. |
Current timezone is GMT Sep 6, 2026, 8:48:41 AM |
