Print at Sep 6, 2026, 9:00:53 AM
Posted by bartleby at Jan 19, 2016, 9:55:22 AM
how to connect walls?
if u want to make a corner (90 degrees) out of 2 single walls, after changing a plan, those 2 walls will not be perfectly connected like when u build this corner at once.
is there a way to fix this?
sometimes tricky in the 3d-view.
maybe i should add a picture if am at home ;).
Posted by okh at Jan 19, 2016, 4:16:01 PM
Re: how to connect walls?
If you do not want to draw the wall again so it joins existing walls, the Advanced plan editing plug-in will let you join (connect) walls. Pay attention to wall direction (reverse if need be) and the order you select the walls you wish to connect. ok
Posted by bartleby at Jan 19, 2016, 8:01:20 PM
again, thx. great program and that for free - must be really much work.
i had problems with my houseproject being too big. with windows 7 i can make pictures in every quality without a problem, but with linux mint i have no chance to make pictures with better or best quality. worked in the beginning when project was smaller. maybe it will work again with ure "connect wall fix" - we will see.
