Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Change color plugin |
| Print at Sep 20, 2026, 2:56:48 AM |
| Posted by digitaltrails at Mar 4, 2016, 4:29:28 AM |
Re: Change color plugin - broken in v5.2 The plugin code is removing the alpha when comparing colours, which isn't a problem. But its also removing the alpha when changing them - this is causing the issue I'm seeing. Looking at the code, it seems I was originally concerned about preserving the destination's original alpha. Only if the new colour has a non 0xFF alpha, should the new alpha be used). I had disabled this as extraneous. I've fixed the code, and re-enabled alpha preservation of the destinations original alpha. So far it looks good. Once I've done some more testing I'll put up a new version. |
| Posted by digitaltrails at Mar 4, 2016, 9:08:48 AM |
Re: Change color plugin - broken in v5.2 I put up a fixed version 1.1 of the Change Color Plugin at sourceforge: https://sourceforge.net/p/sweethome3d/plug-ins/14/#9ea3 The plugin now preserves the existing alpha (transparency) of an item's colour. This means that visible things should stay visible. I also added a special case to restore the alpha of item's broken by the bug. If a colour is changed to itself, the alpha is set to the alpha of the new colour (which is always FF). So I made all my kitchen cabinets visible again by changing colour #E5E4DB to the same colour #E5E4DB. (Manually un-setting invisible causes the colour to be lost). Lastly, I fixed a bug where the plugin was failing to detect when a texture was present (if a texture is present it overrides colour). |
Current timezone is GMT Sep 20, 2026, 2:56:48 AM |
