Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Change color plugin |
| Print at Sep 20, 2026, 2:02:15 AM |
| Posted by hansmex at Jan 9, 2016, 4:18:59 PM |
Re: Change color plugin Michael, Maybe making the border of the swatch thicker might (partially) solve the problem. The coloured line is now rather thin, making it hard to see the colour. Hovering is fine, I'll just have to get used to it. H ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by digitaltrails at Jan 11, 2016, 10:06:45 AM |
Re: Change color plugin new version (v0.3) I've revised the ChangeColor plugin UI (see the attached screen shot). Undo is still unimplemented, I would still advise you to backup your models before using this plugin. The version number has changed from 0.2 to 0.3, so you will need to remove the old jar and replace it with the new one. I've uploaded the jar to the normal place: https://sourceforge.net/p/sweethome3d/plug-ins/14/ Changes:
| Posted by hansmex at Jan 11, 2016, 3:13:53 PM |
Re: Change color plugin new version (v0.3) Michael, Success!! - Swatches now work perfectly. - There are two new windows/lists that show where the selected color is used. - Changing un unchanged colour also works. Great work! Thank you very much for this nice plug-in. Hans ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by okh at Jan 11, 2016, 3:50:05 PM |
Re: Change color plugin new version (v0.3) Indeed, very nice. One to keep. And to help find those annoying different shades. Thanks! ok |
| Posted by Puybaret at Jan 11, 2016, 4:32:14 PM |
Re: Change color plugin new version (v0.3) Thanks for this plugin ![]() It would be nice to program undo/redo. It's really not difficult to implement and you'll find plenty of examples in Sweet Home 3D source code, mainly in PlanController class. Once you retrieved the UndoableEditSupport instance with getUndoableEditSupport(), you just have to create an instance of AbstractUndoableEdit, overriding its undo, redo and getPresentationName methods, and finally call postEdit. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by digitaltrails at Jan 11, 2016, 7:42:32 PM |
Re: Change color plugin new version (v0.3) I do intend to implement undo. I was going to spend some time looking for examples. Thanks for pointing me in the right direction. Thanks for this plugin ![]() It would be nice to program undo/redo. It's really not difficult to implement and you'll find plenty of examples in Sweet Home 3D source code, mainly in PlanController class. Once you retrieved the UndoableEditSupport instance with getUndoableEditSupport(), you just have to create an instance of AbstractUndoableEdit, overriding its undo, redo and getPresentationName methods, and finally call postEdit. |
| Posted by digitaltrails at Jan 12, 2016, 10:45:30 AM |
Re: Change color plugin new version (v0.3) I've implemented undo/redo and uploaded version 1.0 to https://sourceforge.net/p/sweethome3d/plug-ins/14/ I would still advise taking a backup copy of any model before making bulk changes (this code is very new and undetected bugs are always possible). Thanks again for the info. Thanks for this plugin ![]() It would be nice to program undo/redo. It's really not difficult to implement and you'll find plenty of examples in Sweet Home 3D source code, mainly in PlanController class. Once you retrieved the UndoableEditSupport instance with getUndoableEditSupport(), you just have to create an instance of AbstractUndoableEdit, overriding its undo, redo and getPresentationName methods, and finally call postEdit. |
| Posted by hansmex at Jan 12, 2016, 11:25:42 AM |
Re: Change color plugin new version (v0.3) Thank you once again. Undo works nicely, also 2-3 steps back. I tested with v5.2 b1 under W10. H ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by digitaltrails at Mar 3, 2016, 9:04:12 PM |
Re: Change color plugin - broken in v5.2 I've just upgraded to v5.2 and colours changed with the plugin in a model saved with v5.1 seem to be being converted to invisible. Using the plugin in v5.2 seems to incorrectly set the changed colour to invisible (tested on "kitchen island" "Cupboard-units"). The plugin must not be changing the colour in a way that is forward compatible with v5.2. I will try to find time to investigate further. |
| Posted by Puybaret at Mar 3, 2016, 10:53:16 PM |
Re: Change color plugin - broken in v5.2 When the new Invisible radio button is selected, I set the alpha value of the color to 0, and I use this nul alpha to hide some parts in 3D. As all color values in Sweet Home 3D were set with an alpha equal to 0xFF, I didn't think this way of doing could cause any side effect, except you probably handled colors differently. That could explain some reports I received about items becoming invisible when a white color is set. Would that wrong color come from a setting of your plugin? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 20, 2026, 2:02:15 AM |
