Print at Aug 21, 2026, 4:45:34 AM
Posts: 42   Pages: 5   [ Previous Page | 1 2 3 4 5 | Next Page ]
Posted by svedel77 at Sep 26, 2018, 1:11:32 PM
Re: Other rendering quality levels (Advanced settings of photo rendering plug-in)
I think this is a great idea for a plugin. If you could make the possibilities for rendering movies at 60 FPS I would be very greatful.
Posted by harbinger at Sep 26, 2018, 9:27:02 PM
Thanks - i was able to view the PhotoRenderer properties file and that answered the questions well enough. I was able to come up with better renders thanks to the explanations.
I will also take a look at the PDF you pointed to...
Posted by Wolf1066 at Apr 8, 2020, 12:57:59 PM
At the risk of a major "thread necro", I've got to say: what an awesome plugin! Just found it and installed it this evening and had a bit of a play - primarily to get access to the global illumination options - and I'm absolutely rapt!
Many thanks enkonyito.
Crazy Kiwi bloke
Debian "buster" 10 64bit
Sweet Home 3D 6.3 64bit
i5 Quad-core 3.1GHz
8GB 1333MHz DDR3 RAM
Posted by enkonyito at Jul 18, 2022, 4:44:11 AM
Re: Advanced settings of photo rendering plug-in
Version 1.4
- compatible with SH3D-7.0 and higher
EnkoNyito
Posted by Puybaret at Jul 18, 2022, 10:45:15 AM
Thanks for adding YafaRay settings smile
Posted by sjb007 at Jul 18, 2022, 10:44:01 PM
So just to clarify... I have SH3D 7 (with Yafaray built in) and AdvancedSettingsPhotoRendering 1.4 plugin.
Should we uninstall YafarayRendering plugin completely? Or does it still have some function?
Posted by Puybaret at Jul 18, 2022, 11:11:28 PM
I don’t see a good reason to keep YafaRayRendering plug-in installed if you run Sweet Home 3D v7.
It offers less features than YafaRay renderer version in Sweet Home 3D.
Posted by enkonyito at Oct 1, 2023, 10:45:37 PM
Version 1.4.1
  • removal of properties identical to the default ones
EnkoNyito
Posted by CinemaWalls at Sep 4, 2024, 11:31:35 AM
I have already used these settings, but that's the problem, that even the value "normalLens.radius = 1" already gives such a blur as if there is a lens with a 1.8 "hole" on the camera - the DOF is very small.
At the value of radius = 3, the grip is generally several centimeters, almost everything is out of focus. About the other values, more than 3 - I don't understand at all - why are they?
I would like to suggest making several radius values up to one, instead of those useless ones. This would greatly improve the capabilities and quality of the renderers.
I'm applying the renderers for an example
https://imgur.com/a/wJ2WAyb
https://imgur.com/a/17UqX0A
Posted by Puybaret at Sep 4, 2024, 12:44:40 PM
Try a value smaller than 1 (0.5, 0.2 etc)
