Print at Aug 16, 2026, 7:40:46 AM
Posts: 20   Pages: 2   [ 1 2 | Next Page ]
Posted by WhiteVanMan at Jul 16, 2015, 1:17:07 PM
Crash on clicking preferences
Hi
I am using sweethome 3d on an Arch Linux system. Every time I click on preferences the program shuts down instantly and I have to restart it.
Thanks
Posted by hansmex at Jul 16, 2015, 7:00:20 PM
Re: Crash on clicking preferences
Read the FAQ for solutions.
Posted by WhiteVanMan at Jul 16, 2015, 9:44:40 PM
Hi
Thanks for the reply. I found the relevant part in the FAQ after posting. It works if I download the webstart file but I would rather use the sweethome3d from the arch linux repositories, its tidier and looks after the updating. I cannot find the .sf file to amend with -Dcom.eteks.sweethome3d.j3d.checkOffScreenSupport=false arch must have a different method of organising its files. Do you know where it is, is it in a .jar file?
Posted by hansmex at Jul 16, 2015, 10:06:38 PM
I don't know. I use Ubuntu in combination with the installed version, which I download from the website. Installation is no more than extracting the zipped file into a directory.
If you use the web star version, make sure you have Java 6 installed on your system. Other java versions cause problems.
Posted by WhiteVanMan at Jul 16, 2015, 11:30:03 PM
Many thanks
Posted by infozhab at Aug 1, 2015, 3:40:27 AM
Erm, same here on Fedora 22, including the inability to fix as per FAQ recommends. Appending offscreen-false won't do the trick.
Actually, I only need metric measures enabled - is it possible to do it manually?
Posted by goetz at Nov 19, 2015, 1:52:46 AM
I also need to only change the measurements system to metric (the international). How to do it? Editing some config file?
java -jar /usr/share/java/sweethome3d.jar -Dcom.eteks.sweethome3d.j3d.checkOffScreenSupport=false
Doesn't work.
Arch Linux, jre8-openjdk 8.u66, sweethome3d 5.1
Posted by goetz at Nov 19, 2015, 2:25:19 AM
The web method worked.
I installed icedtea-web 1.6.1, which provides javaws, then using the jnlp file http://www.sweethome3d.com/SweetHome3D-NoOffscreen.jnlp from the FAQ:
javaws SweetHome3D-NoOffscreen.jnlp
Or to just to change the measurement unit, edit ~/.eteks/sweethome3d/preferences.xml to a sane value:
<entry key="extensibleUnit">METER</entry>
or
<entry key="extensibleUnit">CENTIMETER</entry>
Posted by Puybaret at Nov 19, 2015, 7:34:01 PM
Doesn't work.
Are you sure that the .jar file you tried in the command is the Jar executable file available at the end of Download page?
Posted by goetz at Nov 19, 2015, 8:23:33 PM
In Arch Linux, the script used to build the installable package, downloads the "Sweet Home 3D executable jar (25.7 MB, same size)" and renames it from SweetHome3D-5.1.jar to sweethome3d.jar in the /usr/share/java/ path. So it should be the same file.
