Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Crash on clicking preferences |
| Print at Sep 29, 2026, 7:32:36 PM |
| Posted by Puybaret at Nov 20, 2015, 9:38:28 PM |
Re: Crash on clicking preferences Ok, then what did you mean by "it doesn't work"? I also wonder if the -D... option should rather be placed before -jar option. Can you try? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by goetz at Nov 21, 2015, 4:42:59 PM |
Re: Crash on clicking preferences This is odd, it did only show the splash screen. Today that command starts the whole application but crashed when opening Preferences. Changing the arguments order as you said, makes Preferences work, thanks! java -Dcom.eteks.sweethome3d.j3d.checkOffScreenSupport=false -jar /usr/share/java/sweethome3d.jar |
| Posted by wood at Jan 4, 2016, 3:32:54 PM |
Re: Crash on clicking preferences Hi, same problem (crash on preferences) on Linux Debian (BunsenLab). Sorry but I did not understand how did you solved, I installed the Debian package and then I tried the version on SourgeForge. The fact is that Java is out of my knowledge and probably is just me that do not understand what you are talkking about. |
| Posted by goetz at Jan 7, 2016, 1:11:04 AM |
Re: Crash on clicking preferences Just go to the download page http://www.sweethome3d.com/download.jsp download the Web Starter http://www.sweethome3d.com/SweetHome3D.jnlp and open it with javaws |
| Posted by Puybaret at Jan 7, 2016, 9:14:49 AM |
Re: Crash on clicking preferences goetz, the JNLP file you referenced won't solve wood's problem. It should rather be http://www.sweethome3d.com/SweetHome3D-NoOffscreen.jnlp ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by wood at Jan 9, 2016, 4:23:42 PM |
Re: Crash on clicking preferences Thanks for replay. I am not using Sweet Home 3D with Java Web Start (do not have Java 6 installed, should I?). So I guess goetz answer did not fit my problem. And the file indicated by Puybaret is a .jnlp, so (for what I understood) is suppose to be used by a Java Web Starter (same story I guess). |
| Posted by goetz at Jan 9, 2016, 7:50:52 PM |
Re: Crash on clicking preferences Puybaret, you are right! wood, just add the checkOffScreenSupport option when invoking sweethome3d. Your path may defer. dpkg -L sweethome3d will show you where the sweethome3d.jar file is. It maybe: |
| Posted by Puybaret at Jan 9, 2016, 8:15:44 PM |
Re: Crash on clicking preferences wood, the only other solution is to add the option: -Dcom.eteks.sweethome3d.j3d.checkOffScreenSupport=falseThen, the last line of the script exec "$PROGRAM_DIR"/jre1.6.0_45/bin/java -Xmx1024m ...exec "$PROGRAM_DIR"/jre1.6.0_45/bin/java -Dcom.eteks.sweethome3d.j3d.checkOffScreenSupport=false -Xmx1024m ...---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by wood at Jan 12, 2016, 10:09:42 PM |
Re: Crash on clicking preferences Thanks again. It works (of course) now. Sorry if I was a little slow understending. |
| Posted by bert.struik at Jan 21, 2016, 6:14:31 AM |
Re: Crash on clicking preferences Had this problem with version 5.1 on Ubuntu 14.04. Used the suggested java fix line from the FAQ. Then I could change preferences. A side effect was that I could not longer delete walls. Removed the java line and then I could delete a wall again. |
Current timezone is GMT Sep 29, 2026, 7:32:36 PM |
