Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: SweetHome 3D does not start in Ubuntu 15.04 |
| Print at Jul 21, 2026, 11:26:04 PM | |
| Posted by mashathung at Apr 28, 2015, 1:18:53 PM |
SweetHome 3D does not start in Ubuntu 15.04 I get following error on running sweethome3d Version (4.5) in ubuntu 15.04(freshly installed) ------------------------------------------------------------- root@library:/home# sweethome3d Picked up JAVA_TOOL_OPTIONS: -javaagent:/usr/share/java/jayatanaag.jar Java 3D: implicit antialiasing enabled (java:2447): GLib-GIO-CRITICAL **: g_dbus_connection_register_object: assertion 'G_IS_DBUS_CONNECTION (connection)' failed (java:2447): GLib-GIO-CRITICAL **: g_dbus_connection_register_object: assertion 'G_IS_DBUS_CONNECTION (connection)' failed (java:2447): GLib-GIO-CRITICAL **: g_dbus_connection_get_unique_name: assertion 'G_IS_DBUS_CONNECTION (connection)' failed (java:2447): GLib-GIO-CRITICAL **: g_dbus_connection_register_object: assertion 'G_IS_DBUS_CONNECTION (connection)' failed (java:2447): GLib-GIO-CRITICAL **: g_dbus_connection_register_object: assertion 'G_IS_DBUS_CONNECTION (connection)' failed (java:2447): GLib-GIO-CRITICAL **: g_dbus_connection_get_unique_name: assertion 'G_IS_DBUS_CONNECTION (connection)' failed (java:2447): GLib-GIO-CRITICAL **: g_dbus_connection_register_object: assertion 'G_IS_DBUS_CONNECTION (connection)' failed (java:2447): GLib-GIO-CRITICAL **: g_dbus_connection_register_object: assertion 'G_IS_DBUS_CONNECTION (connection)' failed (java:2447): GLib-GIO-CRITICAL **: g_dbus_connection_get_unique_name: assertion 'G_IS_DBUS_CONNECTION (connection)' failed (java:2447): GLib-GIO-CRITICAL **: g_dbus_connection_register_object: assertion 'G_IS_DBUS_CONNECTION (connection)' failed (java:2447): GLib-GIO-CRITICAL **: g_dbus_connection_register_object: assertion 'G_IS_DBUS_CONNECTION (connection)' failed (java:2447): GLib-GIO-CRITICAL **: g_dbus_connection_get_unique_name: assertion 'G_IS_DBUS_CONNECTION (connection)' failed (java:2447): GLib-GIO-CRITICAL **: g_dbus_connection_register_object: assertion 'G_IS_DBUS_CONNECTION (connection)' failed (java:2447): GLib-GIO-CRITICAL **: g_dbus_connection_register_object: assertion 'G_IS_DBUS_CONNECTION (connection)' failed (java:2447): GLib-GIO-CRITICAL **: g_dbus_connection_get_unique_name: assertion 'G_IS_DBUS_CONNECTION (connection)' failed Exception in thread "AWT-EventQueue-0" java.util.ServiceConfigurationError: javax.imageio.spi.ImageWriterSpi: Provider org.freehep.graphicsio.raw.RawImageWriterSpi not found at java.util.ServiceLoader.fail(ServiceLoader.java:231) at java.util.ServiceLoader.access$300(ServiceLoader.java:181) at java.util.ServiceLoader$LazyIterator.next(ServiceLoader.java:365) at java.util.ServiceLoader$1.next(ServiceLoader.java:445) at javax.imageio.spi.IIORegistry.registerApplicationClasspathSpis(IIORegistry.java:210) at javax.imageio.spi.IIORegistry.<init>(IIORegistry.java:138) at javax.imageio.spi.IIORegistry.getDefaultInstance(IIORegistry.java:159) at javax.imageio.ImageIO.<clinit>(ImageIO.java:65) at com.eteks.sweethome3d.swing.SwingTools.createCustomCursor(Unknown Source) at com.eteks.sweethome3d.swing.PlanComponent.createCustomCursor(Unknown Source) at com.eteks.sweethome3d.swing.PlanComponent.createCustomCursor(Unknown Source) at com.eteks.sweethome3d.swing.PlanComponent.<init>(Unknown Source) at com.eteks.sweethome3d.swing.MultipleLevelsPlanPanel.createPlanComponent(Unknown Source) at com.eteks.sweethome3d.swing.MultipleLevelsPlanPanel.createComponents(Unknown Source) at com.eteks.sweethome3d.swing.MultipleLevelsPlanPanel.<init>(Unknown Source) at com.eteks.sweethome3d.swing.SwingViewFactory.createPlanView(Unknown Source) at com.eteks.sweethome3d.viewcontroller.PlanController.getView(Unknown Source) at com.eteks.sweethome3d.viewcontroller.PlanController$SelectionState.enter(Unknown Source) at com.eteks.sweethome3d.viewcontroller.PlanController.setState(Unknown Source) at com.eteks.sweethome3d.viewcontroller.PlanController.<init>(Unknown Source) at com.eteks.sweethome3d.viewcontroller.HomeController.getPlanController(Unknown Source) at com.eteks.sweethome3d.swing.HomePane.createActions(Unknown Source) at com.eteks.sweethome3d.swing.HomePane.<init>(Unknown Source) at com.eteks.sweethome3d.swing.SwingViewFactory.createHomeView(Unknown Source) at com.eteks.sweethome3d.viewcontroller.HomeController.getView(Unknown Source) at com.eteks.sweethome3d.HomeFramePane.<init>(Unknown Source) at com.eteks.sweethome3d.HomeFrameController.getView(Unknown Source) at com.eteks.sweethome3d.HomeFrameController.displayView(Unknown Source) at com.eteks.sweethome3d.SweetHome3D$4.collectionChanged(Unknown Source) at com.eteks.sweethome3d.model.CollectionChangeSupport.fireCollectionChanged(Unknown Source) at com.eteks.sweethome3d.model.HomeApplication.addHome(Unknown Source) at com.eteks.sweethome3d.SweetHome3D.showDefaultHomeFrame(Unknown Source) at com.eteks.sweethome3d.SweetHome3D.start(Unknown Source) at com.eteks.sweethome3d.SweetHome3D$5.run(Unknown Source) at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:312) at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:745) at java.awt.EventQueue.access$300(EventQueue.java:103) at java.awt.EventQueue$3.run(EventQueue.java:706) at java.awt.EventQueue$3.run(EventQueue.java:704) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76) at java.awt.EventQueue.dispatchEvent(EventQueue.java:715) at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:242) at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:161) at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:150) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:146) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:138) at java.awt.EventDispatchThread.run(EventDispatchThread.java:91) |
| Posted by sly13 at May 26, 2015, 11:03:47 PM |
Re: SweetHome 3D does not start in Ubuntu 15.04 Same problem here as a normal user. Must be a permission problem because it works OK when launching sweethome3d as root. |
Current timezone is GMT Jul 21, 2026, 11:26:04 PM |
