Total posts in this thread: 2
Previous Thread This topic has been viewed 6297 times and has 1 reply Next Thread
mashathung
SweetHome 3D does not start in Ubuntu 15.04
I get following error on running sweethome3d Version (4.5) in ubuntu 15.04(freshly installed)
root@library:/home# sweethome3d
Picked up JAVA_TOOL_OPTIONS: -javaagent:/usr/share/java/jayatanaag.jar
Java 3D: implicit antialiasing enabled
(java:2447): GLib-GIO-CRITICAL **: g_dbus_connection_register_object: assertion 'G_IS_DBUS_CONNECTION (connection)' failed
(java:2447): GLib-GIO-CRITICAL **: g_dbus_connection_get_unique_name: assertion 'G_IS_DBUS_CONNECTION (connection)' failed
Exception in thread "AWT-EventQueue-0" java.util.ServiceConfigurationError: javax.imageio.spi.ImageWriterSpi: Provider org.freehep.graphicsio.raw.RawImageWriterSpi not found
at java.util.ServiceLoader.fail(ServiceLoader.java:231)
at java.util.ServiceLoader.access$300(ServiceLoader.java:181)
at java.util.ServiceLoader$LazyIterator.next(ServiceLoader.java:365)
at java.util.ServiceLoader$1.next(ServiceLoader.java:445)
at javax.imageio.spi.IIORegistry.registerApplicationClasspathSpis(IIORegistry.java:210)
at javax.imageio.spi.IIORegistry.<init>(IIORegistry.java:138)
at javax.imageio.spi.IIORegistry.getDefaultInstance(IIORegistry.java:159)
at javax.imageio.ImageIO.<clinit>(ImageIO.java:65)
at com.eteks.sweethome3d.swing.SwingTools.createCustomCursor(Unknown Source)
at com.eteks.sweethome3d.swing.PlanComponent.createCustomCursor(Unknown Source)
at com.eteks.sweethome3d.swing.PlanComponent.<init>(Unknown Source)
at com.eteks.sweethome3d.swing.MultipleLevelsPlanPanel.createPlanComponent(Unknown Source)
at com.eteks.sweethome3d.swing.MultipleLevelsPlanPanel.createComponents(Unknown Source)
at com.eteks.sweethome3d.swing.MultipleLevelsPlanPanel.<init>(Unknown Source)
at com.eteks.sweethome3d.swing.SwingViewFactory.createPlanView(Unknown Source)
at com.eteks.sweethome3d.viewcontroller.PlanController.getView(Unknown Source)
at com.eteks.sweethome3d.viewcontroller.PlanController$SelectionState.enter(Unknown Source)
at com.eteks.sweethome3d.viewcontroller.PlanController.setState(Unknown Source)
at com.eteks.sweethome3d.viewcontroller.PlanController.<init>(Unknown Source)
at com.eteks.sweethome3d.viewcontroller.HomeController.getPlanController(Unknown Source)
at com.eteks.sweethome3d.swing.HomePane.createActions(Unknown Source)
at com.eteks.sweethome3d.swing.HomePane.<init>(Unknown Source)
at com.eteks.sweethome3d.swing.SwingViewFactory.createHomeView(Unknown Source)
at com.eteks.sweethome3d.viewcontroller.HomeController.getView(Unknown Source)
at com.eteks.sweethome3d.HomeFramePane.<init>(Unknown Source)
at com.eteks.sweethome3d.HomeFrameController.getView(Unknown Source)
at com.eteks.sweethome3d.HomeFrameController.displayView(Unknown Source)
at com.eteks.sweethome3d.SweetHome3D$4.collectionChanged(Unknown Source)
at com.eteks.sweethome3d.model.CollectionChangeSupport.fireCollectionChanged(Unknown Source)
at com.eteks.sweethome3d.model.HomeApplication.addHome(Unknown Source)
at com.eteks.sweethome3d.SweetHome3D.showDefaultHomeFrame(Unknown Source)
at com.eteks.sweethome3d.SweetHome3D.start(Unknown Source)
at com.eteks.sweethome3d.SweetHome3D$5.run(Unknown Source)
at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:312)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:745)
at java.awt.EventQueue.access$300(EventQueue.java:103)
at java.awt.EventQueue$3.run(EventQueue.java:706)
at java.awt.EventQueue$3.run(EventQueue.java:704)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:715)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:242)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:161)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:150)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:146)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:138)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:91)
[Apr 28, 2015, 1:18:53 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
sly13
Re: SweetHome 3D does not start in Ubuntu 15.04
Same problem here as a normal user.
Must be a permission problem because it works OK when launching sweethome3d as root.
[May 26, 2015, 11:03:47 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
