Print at Sep 15, 2026, 3:57:42 AM
Posted by fhoofman at Mar 10, 2015, 12:28:43 PM
dimensions on height or 3d view
I like to know, how to create dimensions on 3d view. so when I create a design, I'd like people to know how high the building I designed base on my drawing.
thanks
sorry for bad english
Posted by okh at Mar 10, 2015, 10:53:23 PM
Re: dimensions on height or 3d view
Logically the answer is placing an object with known dimensions in the plan that will show dimensions in the 3D view, e.g. like this: SF SH3D 3D model 326. Silly, I know, but I use it from time to time. ok
Posted by fhoofman at Mar 11, 2015, 2:52:30 AM
the tricks will do on a personal matters. thanks
but I don't think that's a proper way to show to the workers & contractors. is there any other way to measure dimensions on 3d?
Posted by okh at Mar 11, 2015, 8:59:39 AM
FYI: And if it is any consolation, there is a feature request on this (484). The issue occasionally comes up in the forum - e.g. 5498: Lateral view of indoor walls and 5416: House designed with Sweet Home 3D.
Posted by bert.struik at Nov 16, 2025, 1:56:40 AM
Has a side view with dimensions been implemented?
It would be very handy to measure from for building.
I do not know the complications of grouping and rotating the plan view 90 degrees in X or Y, and then adding the dimensions.
Posted by Daniels118 at Nov 16, 2025, 3:36:00 PM
Perhaps you may try my plugins:
https://www.youtube.com/watch?v=9XiA-awqVak
Please note that 3D dimension lines plugin has been released with SH3D 7.2, there are known problems with later versions.
Posted by bert.struik at Nov 16, 2025, 9:30:04 PM
Thank you very much.
I have version 7.2 available and will use the plug in. Had gone to 7.5.
Posted by dorin at Nov 17, 2025, 9:01:24 AM
From version 7.2 we have elevation dimensions which will appear in Side View plugin 1.1.
Posted by MarioSambol at Nov 17, 2025, 12:10:04 PM
All dimensions can be displayed in 3D view. Doubleclick on the dimension line opens the "Modify dimension" window. Select whether it is a Plan dimension or an Elevation dimension and whether the dimension line is visible or not in the 3D view.To have a printable document you must use Side View and save in *.png format. Selecting the view you want depends on the camera angle in the virtual visit (0, 90, 180, 270 degrees).
