Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: Failed to generate folder |
| Print at Sep 20, 2026, 11:11:12 AM | View all posts in this thread on one page |
| Posted by Lumaja at Jan 18, 2015, 7:11:48 AM |
Failed to generate folder Ubuntu 12.04 Sweet Home 3D ver. 4.5 After installing SH and open the working file various times, it failed to generate in .eteks the folder “sweethome3d”. How should I generated this folder? Thank you. |
| Posted by Puybaret at Jan 18, 2015, 8:27:57 PM |
Re: Failed to generate folder Very strange error. It would have succeeded to create ".eteks" folder in your home but not a folder inside that folder??? Try to create it yourself running the following command in a Terminal window: mkdir ~/.eteks/sweethome3d---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Lumaja at Jan 19, 2015, 6:32:48 AM |
Re: Failed to generate folder Follow your advice and the folder is now in .eteks. I have to explain how this come about. After you help me with plugins>AdvancedEditing.sh3p all was right the “Connect Walls” was working until the other day after starting SH notice “Connect Walls” was shaded, try to find why was unsuccessful I fill a new thread that was not answered, continue to find the problem change from ver. 4.5 to ver. 4.4 still the same, as I understand SH generates the folder sweethome3d from .eteks decided to delete the folder and reinstall SH this is the cause I fill a new thread. To continue I would prefer with your guidance please. Thank you |
Current timezone is GMT Sep 20, 2026, 11:11:12 AM |
