Print at Sep 20, 2026, 1:15:03 PM
Posted by Lumaja at Jan 18, 2015, 7:11:48 AM
Failed to generate folder
Ubuntu 12.04
Sweet Home 3D ver. 4.5
After installing SH and open the working file various times, it failed to generate
in .eteks the folder “sweethome3d”.
How should I generated this folder?
Thank you.
Posted by Puybaret at Jan 18, 2015, 8:27:57 PM
Re: Failed to generate folder
Very strange error. It would have succeeded to create ".eteks" folder in your home but not a folder inside that folder???
Try to create it yourself running the following command in a Terminal window:
mkdir ~/.eteks/sweethome3d
Posted by Lumaja at Jan 19, 2015, 6:32:48 AM
Follow your advice and the folder is now in .eteks.
I have to explain how this come about.
After you help me with plugins>AdvancedEditing.sh3p all was right the “Connect Walls” was
working until the other day after starting SH notice “Connect Walls” was shaded, try to find
why was unsuccessful I fill a new thread that was not answered, continue to find the problem change from ver. 4.5 to ver. 4.4 still the same, as I understand SH generates the folder sweethome3d from .eteks decided to delete the folder and reinstall SH this is the cause I fill a new thread.
To continue I would prefer with your guidance please.
Thank you
