Print at Sep 27, 2026, 1:29:30 PM View all posts in this thread on one page
Posted by hrk at Nov 10, 2014, 1:19:19 PM
4 walls ,
hi.
i'm new to this forum ,
1. i have 4 texture for 4 side of the wall. How do i achieve this?
2. how do i donate a small token to this cause ? good job on this. impressive.
thanks
Posted by Puybaret at Nov 10, 2014, 9:35:08 PM
Re: 4 walls ,
Welcome,
If you count the top and the bottom of a wall, you could even wonder how to set the 6 sides of a wall! wink
But I guess you want to change only the vertical parts. As Sweet Home 3D offers to change only the left, right and top sides, you'll have to create very thin walls that you put at each end of the main wall.
Thanks. smile
You can use the Donate button found at the bottom of each page, or go to the Donate page.
Posted by okh at Nov 10, 2014, 10:15:43 PM
Re: 4 walls ,
Maybe I misunderstand, but you can
1. split walls and assign different textures to different wall elements,
2. use a picture editor and edit the textures before applying them, see thread 5438
Posted by hrk at Nov 11, 2014, 3:17:29 AM
Re: 4 walls ,
thanks guys !
i got it. just do 4 walls,joint them and apply 4 diff textures.
i was meddling with rooms no wonder the issue .
cheers
