Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Sloping walls in floor plan of the House |
| Print at Sep 15, 2026, 12:48:33 PM | View all posts in this thread on one page |
| Posted by Lavondyss at Oct 15, 2014, 8:21:00 PM |
Sloping walls in floor plan of the House Hello,could someone advise how to do sloping walls in floor plan (top view) of the house? If it is possible, step by step I am a beginner. Thank you very much.[/url] |
| Posted by okh at Oct 16, 2014, 8:44:43 AM |
Re: Sloping walls in floor plan of the House Indicate Height at start and Height at end in the Modify wall dialogue (double-click the wall or select and use Plan - Modify wall). Hint - Plan - Split wall divides the wall in two equal parts, useful for gables. If you intend to use the wall for a staircase or something similar, you may also want to look at a recent blog post on how to create a hole in the bottom of the wall. |
| Posted by Lavondyss at Oct 16, 2014, 9:28:52 PM |
Re: Sloping walls in floor plan of the House You did not understand my question. I mean, that the floor projection (top view) is not rectangular (because o ur house is 183 years old). Therefore, the walls in the square room have not the same lengh. I need to draw them in this software. |
| Posted by okh at Oct 16, 2014, 9:44:40 PM |
Re: Sloping walls in floor plan of the House Ah - so sorry - but I still do not understand your question. IF you mean the angles of the walls (familiar - my childhood home is 200+ years old), you should try to disable magnetism (either in Preferences or by pressing ALT) when you draw your walls. But if your house is as skewed as mine, you probably want to enter the co-ordinates manually by editing properties of each wall. But maybe I am still not getting it? ok |
Current timezone is GMT Sep 15, 2026, 12:48:33 PM |
