Print at Aug 16, 2026, 11:29:58 AM View all posts in this thread on one page
Posted by gundeg at Sep 11, 2014, 6:30:41 AM
confused   Is it possible to create glass wall?
I need to create transparent glass walls. is it possible? how? smile
Posted by okh at Sep 11, 2014, 10:33:22 AM
Re: Is it possible to create glass wall?
Easiest - I find - is to use a transparent object. Import as window/door if you want it to run flush with the wall, or use it instead of a wall.
This model (posted in SourceForge 3D models 303) is what I use. Save the zip file and drag/drop into your model (check for door/window). Adjust size and change colour to your liking. If you need a frame for the glass wall, create a wall correct thickness and insert the transparent object into the wall.
Posted by hansmex at Sep 11, 2014, 1:05:48 PM
OKH,
I like the colour of the glass, but unfortunately the glass isnt't very transparent at Q3 (not shown) and Q4 (shown).
image in Q2
image in Q4
Posted by okh at Sep 11, 2014, 2:20:19 PM
Ah yes - I forgot to add that the glass wall is set to be reflective in rendering q3/q4 (using g sweethome3d_window_mirror in the .obj file - like a mirror - see the rest of the thread).
This example - glass_walls_reflection_and_not.sh3d - shows the same window with reflection (marked with a danger sign) and without reflection.
I posted the two other windows used in the example too in case the lab does not want reflective glass walls. As for the general transparency, you could change the d value in the .mtl file. But I guess it is the rendering you were after...
Posted by gundeg at Sep 12, 2014, 9:43:55 AM
thanks a lot
Posted by josephrohdes221 at Sep 30, 2014, 9:30:55 AM
Really it is possible with the help of experts of this forum only, nicely explained and helped me a lot.
