Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: Is it possible to create glass wall? |
| Print at Aug 16, 2026, 11:25:23 PM | |
| Posted by gundeg at Sep 11, 2014, 6:30:41 AM |
Is it possible to create glass wall?I need to create transparent glass walls. is it possible? how? ![]() |
| Posted by okh at Sep 11, 2014, 10:33:22 AM |
Re: Is it possible to create glass wall? Easiest - I find - is to use a transparent object. Import as window/door if you want it to run flush with the wall, or use it instead of a wall. This model (posted in SourceForge 3D models 303) is what I use. Save the zip file and drag/drop into your model (check for door/window). Adjust size and change colour to your liking. If you need a frame for the glass wall, create a wall correct thickness and insert the transparent object into the wall. ok |
| Posted by hansmex at Sep 11, 2014, 1:05:48 PM |
Re: Is it possible to create glass wall? OKH, I like the colour of the glass, but unfortunately the glass isnt't very transparent at Q3 (not shown) and Q4 (shown). Hans image in Q2 image in Q4 ![]() ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by okh at Sep 11, 2014, 2:20:19 PM |
Re: Is it possible to create glass wall? Ah yes - I forgot to add that the glass wall is set to be reflective in rendering q3/q4 (using g sweethome3d_window_mirror in the .obj file - like a mirror - see the rest of the thread). This example - glass_walls_reflection_and_not.sh3d - shows the same window with reflection (marked with a danger sign) and without reflection. I posted the two other windows used in the example too in case the lab does not want reflective glass walls. As for the general transparency, you could change the d value in the .mtl file. But I guess it is the rendering you were after... ok |
| Posted by gundeg at Sep 12, 2014, 9:43:55 AM |
Re: Is it possible to create glass wall? thanks a lot |
| Posted by josephrohdes221 at Sep 30, 2014, 9:30:55 AM |
Re: Is it possible to create glass wall? Really it is possible with the help of experts of this forum only, nicely explained and helped me a lot. |
Current timezone is GMT Aug 16, 2026, 11:25:23 PM |
