Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Stairs going down |
| Print at Sep 19, 2026, 3:58:53 PM | View all posts in this thread on one page |
| Posted by Leulath at Aug 6, 2014, 7:53:51 PM |
Stairs going down How can I manage to make the stairs going down instead of going up? It's not possible to use negative parameters for the ground distance. Or are there some stairs available 'suggests' going down? |
| Posted by Puybaret at Aug 7, 2014, 1:50:10 AM |
Re: Stairs going down You should create an underground level and the stairs to that level. To make a upper level becoming an underground level, simply modify the elevation of the level with a negative value. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by sesquiped at Aug 8, 2014, 1:22:51 AM |
Re: Stairs going down I am trying to do this too, and I don't understand how to make the elevation negative. Could you explain? Thank you! |
| Posted by Puybaret at Aug 8, 2014, 12:19:04 PM |
Re: Stairs going down Once you added a level, you can modify its elevation by double-clicking on its tab, or by selecting it and choosing the Plan > Modify level menu item. In the modification dialog that will be shown, simply enter a negative value in the Elevation field. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 19, 2026, 3:58:53 PM |
