Print at Sep 19, 2026, 6:42:25 PM
Posted by Leulath at Aug 6, 2014, 7:53:51 PM
Stairs going down
How can I manage to make the stairs going down instead of going up? It's not possible to use negative parameters for the ground distance. Or are there some stairs available 'suggests' going down?
Posted by Puybaret at Aug 7, 2014, 1:50:10 AM
Re: Stairs going down
You should create an underground level and the stairs to that level. To make a upper level becoming an underground level, simply modify the elevation of the level with a negative value.
Posted by sesquiped at Aug 8, 2014, 1:22:51 AM
I am trying to do this too, and I don't understand how to make the elevation negative. Could you explain? Thank you!
Posted by Puybaret at Aug 8, 2014, 12:19:04 PM
Once you added a level, you can modify its elevation by double-clicking on its tab, or by selecting it and choosing the Plan > Modify level menu item. In the modification dialog that will be shown, simply enter a negative value in the Elevation field.
