Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: swimming pool elevation |
| Print at Sep 15, 2026, 12:43:47 PM | |
| Posted by JUGGERNAUT at Jul 17, 2014, 4:29:26 PM |
swimming pool elevation help please, how do I recess my pool into the ground to give me the correct rendering in 3d view? |
| Posted by okh at Jul 20, 2014, 12:56:40 PM |
Re: swimming pool elevation Depends how you design your pool and whether you use a model of a pool. Try using a negative level (Add Level, and edit it to the "bottom of the pool", say -220cm). You can draw your pool as a room with walls on the negative (subterranean) level where the walls protrude above ground to form the edge of the pool. ok |
| Posted by JUGGERNAUT at Jul 21, 2014, 12:40:58 PM |
Re: swimming pool elevation Thanks your advice makes a lot of sense I will try and then let you know the outcome |
| Posted by okh at Jul 22, 2014, 12:08:43 PM |
Re: swimming pool elevation Pools can be done with much of the same approach as terrain geometry. Posted an example of a pool (in sh3d format) with some extra pool models. Hope this can be of help. ok |
| Posted by okh at Sep 5, 2014, 11:37:37 AM |
Re: swimming pool elevation Noticed the new blog post on how to design a swimming pool, with an example .sh3d file. Thanks, useful guidance to the basic steps of how to create a pool, using textures, curved walls and do model design with the help of SH3D. And a very nice design too. ok How to design a swimming pool ![]() |
| Posted by Jimgsm at May 23, 2019, 5:35:24 PM |
Re: swimming pool elevation Yes, you advice very useful, thanks) |
Current timezone is GMT Sep 15, 2026, 12:43:47 PM |
