Print at Sep 19, 2026, 5:47:09 PM View all posts in this thread on one page
Posted by jmg_rose at Jul 11, 2014, 6:24:16 AM
Invisible floor on upper level room.
I have a basement that is smaller the level above. The room above the basement has no floor. I see there was a defect that was fixed in 4.3
"Fixed a bug that prevented to display correctly some floor rooms in the 3D view when they overlap."
but I'm using version 4.4 with (Java 1.6.0_45 / 64 bit / 0.9 GB max) on Windows 7 x64.
I'm not sure if this is a defect or something I did wrong drawing my plans. I'm a fairly new user.
The upper level does have a floor thickness (4 3/4") and elevation of 0. The basement level has an elevation of -10' and a height of 9' 7 1/4" I'm not sure what else to check.
Posted by hansmex at Jul 11, 2014, 1:45:16 PM
Re: Invisible floor on upper level room.
Can you share your sh3d-file?
Posted by jmg_rose at Jul 16, 2014, 4:56:40 AM
Yes it's at:
http://www.mediafire.com/download/4pgznb6u7jmuvm8/NoLivingroomFloor.sh3d
Posted by hansmex at Jul 16, 2014, 7:59:26 AM
Jeremy,
You didn't create floors in your plan, so it's logical that you can't see them.
Click the Floor button (to the right of the Walls button), then double-click in each room.
Problem solved!
Tip: read the Plug-in manual, install the AdvancedEdit plug-in and use the Connect walls function to connect the walls in the top-left corner of your design.
Posted by jmg_rose at Jul 18, 2014, 4:48:15 AM
I suspected is was some stupid little thing I missed. Thank you!
