Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Invisible floor on upper level room. |
| Print at Sep 19, 2026, 6:42:43 PM | |
| Posted by jmg_rose at Jul 11, 2014, 6:24:16 AM |
Invisible floor on upper level room. I have a basement that is smaller the level above. The room above the basement has no floor. I see there was a defect that was fixed in 4.3 "Fixed a bug that prevented to display correctly some floor rooms in the 3D view when they overlap." but I'm using version 4.4 with (Java 1.6.0_45 / 64 bit / 0.9 GB max) on Windows 7 x64. I'm not sure if this is a defect or something I did wrong drawing my plans. I'm a fairly new user. The upper level does have a floor thickness (4 3/4") and elevation of 0. The basement level has an elevation of -10' and a height of 9' 7 1/4" I'm not sure what else to check. |
| Posted by hansmex at Jul 11, 2014, 1:45:16 PM |
Re: Invisible floor on upper level room. Can you share your sh3d-file? ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by jmg_rose at Jul 16, 2014, 4:56:40 AM |
Re: Invisible floor on upper level room. Yes it's at: http://www.mediafire.com/download/4pgznb6u7jmuvm8/NoLivingroomFloor.sh3d |
| Posted by hansmex at Jul 16, 2014, 7:59:26 AM |
Re: Invisible floor on upper level room. Jeremy, You didn't create floors in your plan, so it's logical that you can't see them. Click the Floor button (to the right of the Walls button), then double-click in each room. Problem solved! Hans Tip: read the Plug-in manual, install the AdvancedEdit plug-in and use the Connect walls function to connect the walls in the top-left corner of your design. ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by jmg_rose at Jul 18, 2014, 4:48:15 AM |
Re: Invisible floor on upper level room. I suspected is was some stupid little thing I missed. Thank you! |
Current timezone is GMT Sep 19, 2026, 6:42:43 PM |
