Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: SW3D stuck on startup...please help |
| Print at Oct 5, 2026, 8:02:05 PM | View all posts in this thread on one page |
| Posted by soho2000 at Apr 2, 2014, 1:59:10 PM |
SW3D stuck on startup...please help hi everybody, i was working on a quite big plan...and from time to time the software jammed...restarting Sweethome3D helped... now i am stuck...because when the software opens it tries to re-open the last file and instantly get stuck again... what can i do? are there auto-save files to delete somewhere? please give me a hint=) |
| Posted by Puybaret at Apr 2, 2014, 3:24:51 PM |
Re: SW3D stuck on startup...please help The folder where recovered files are stored depends on your system: - Under Windows Vista / 7 / 8, it's C:\Users\user\AppData\Roaming\eTeks\Sweet Home 3D\recovery folder - Under Windows XP and previous versions of Windows, it's C:\Documents and Settings\user\Application Data\eTeks\Sweet Home 3D\recovery folder - Under Mac OS X, it's the Library/Application Support/eTeks/Sweet Home 3D/recovery subfolder of your user folder - Under Linux, it's .eteks/sweethome3d/recovery subfolder of your user folder - With the portable version, it's data/recovery subfolder of Sweet Home 3D folder. Did you try to increase the max memory to see if it works better? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by soho2000 at Apr 3, 2014, 11:49:02 AM |
Re: SW3D stuck on startup...please help Merci! Emmanuel;) i managed to get rid of the faulty recovery file which caused the problem. put the RAM value to 4096... can´t tell if performance is better, doesn´t feel better... my machine is a 2012 hackintosh 24GB RAM for Videoediting (Premiere and AE) GPU with CUDA support but its working=) yay=) |
Current timezone is GMT Oct 5, 2026, 8:02:05 PM |
