Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: Program gets stuck! |
| Print at Aug 25, 2026, 5:19:57 PM | |
| Posted by room103 at Jan 10, 2014, 8:46:01 PM |
Program gets stuck! Hi there, I've been enjoying Sweet Home 3D for a very long time. Previously I used AMD Athlon 64 and everything worked just fine. I bought Intel i5-4440 and now the program doesn't work: 1. If I double-click a .sh3d file I previously used, the program stucks right after showing the small splash logo. 2. If I run the program (without opening a .sh3d file), it seems to work fine, but then suddenly get stuck after a while. Any idea at all? I'm using Windows XP 32-bit (yeah, yeah, I know, but I ilke XP, can't stand Win7). I really need Sweet Home 3D - it's excellent and I don't want to switch to any other program. Please help! |
| Posted by Puybaret at Jan 10, 2014, 9:30:20 PM |
Re: Program gets stuck! Did you try the suggestions in the FAQ? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by room103 at Jan 10, 2014, 10:28:15 PM |
Re: Program gets stuck! Thanks a lot, Puybaret. I tried everything and seems like the 2D JAR file is the only thing that works for me. Better than nothing. Thanks! |
| Posted by room103 at Jan 10, 2014, 10:32:27 PM |
Re: Program gets stuck! Wait, I just found a solution: Display Properties -> Advanced -> Troubleshooting -> Hardware acceleration: Set it to one tick below "Full" ("Disable cursor and bitmap accelerations"). Works like a charm! I wrote the solution above so other people can use it too. I think it should be added to the FAQ. Thanks again, Puybaret! |
Current timezone is GMT Aug 25, 2026, 5:19:57 PM |
