Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Can I customize the render settings |
| Print at Sep 19, 2026, 6:01:05 PM |
| Posted by sree.arun.kr at Oct 31, 2013, 6:26:03 PM |
Can I customize the render settingsSir,I wish to customize the default render preset quality settings, the properties like anti-aliasing,texture filtering,caustic shadow. Because this image takes 2 minute to render in 3rd quality render setting http://s21.postimg.org/jnkz2tetj/002.jpg But its shadow biasing is not good. And this image taken 48 minute to render in 4th(Best) quality render http://s13.postimg.org/se2d8qepz/003.jpg If I can control over it then it is possible to adjust lights,texture resolution,objects snapping... So Is it possible to inject a new code or edit any current code table?. Thx in advance. & Thanks SWEET Home 3D team for the new version ---------------------------------------- ![]() |
| Posted by okh at Oct 31, 2013, 8:16:21 PM |
Re: Can I customize the render settings That sounds strange. Even my totally non-graphically minded machine works faster. A lot faster. Could there be another issue? ok |
| Posted by Puybaret at Nov 1, 2013, 1:16:07 AM |
Re: Can I customize the render settings Please read this thread and this one. It won't let you change all the parameters you wish but it's a nice start. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by sree.arun.kr at Nov 4, 2013, 7:41:24 PM |
Re: Can I customize the render settings Thanks, Emmanuel Puybaret Here is my trial Render-1 in HQ & it takes 6 minutes ![]() with default settings, -Xms1024m -Xmx1536m -Dcom.eteks.sweethome3d.j3d.PhotoRenderer.highQuality.globalIllumination=default -Dcom.eteks.sweethome3d.j3d.PhotoRenderer.highQuality.diffusedBounces=1 -Dcom.eteks.sweethome3d.j3d.PhotoRenderer.highQuality.causticsPhotons=0 -Dcom.eteks.sweethome3d.j3d.PhotoRenderer.highQuality.shininessShader=silk -Dcom.eteks.sweethome3d.j3d.PhotoRenderer.highQuality.antiAliasing.min=1 -Dcom.eteks.sweethome3d.j3d.PhotoRenderer.highQuality.antiAliasing.max=2 , Here is my trial Render-2 in HQ & it takes 1 Hr.3minutes ![]() with High settings, -Xms1024m -Xmx1536m -Dcom.eteks.sweethome3d.j3d.PhotoRenderer.highQuality.globalIllumination=path -Dcom.eteks.sweethome3d.j3d.PhotoRenderer.highQuality.diffusedBounces=3 -Dcom.eteks.sweethome3d.j3d.PhotoRenderer.highQuality.causticsPhotons=1000000 -Dcom.eteks.sweethome3d.j3d.PhotoRenderer.highQuality.shininessShader=default -Dcom.eteks.sweethome3d.j3d.PhotoRenderer.highQuality.antiAliasing.min=1 -Dcom.eteks.sweethome3d.j3d.PhotoRenderer.highQuality.antiAliasing.max=2 & Here is my trial Render-3 in HQ & it takes 3minute.20Sec ![]() with Optimize settings, -Xms1024m -Xmx1536m -Dcom.eteks.sweethome3d.j3d.PhotoRenderer.highQuality.globalIllumination=path -Dcom.eteks.sweethome3d.j3d.PhotoRenderer.highQuality.diffusedBounces=0 -Dcom.eteks.sweethome3d.j3d.PhotoRenderer.highQuality.causticsPhotons=0 -Dcom.eteks.sweethome3d.j3d.PhotoRenderer.highQuality.shininessShader=silk -Dcom.eteks.sweethome3d.j3d.PhotoRenderer.highQuality.antiAliasing.min=1 -Dcom.eteks.sweethome3d.j3d.PhotoRenderer.highQuality.antiAliasing.max=1 It give me a lots of work experience in all the way Thank you once again for posting information's. , ![]() ---------------------------------------- ![]() |
| Posted by sree.arun.kr at Nov 4, 2013, 8:00:00 PM |
Re: Can I customize the render settings I have a simple question that which keyboard shortcut used to visitor's head angle movement, in guide it shows a striken Up/down arrow which means shift+up/down arrow?. Not worked for me. 8( ---------------------------------------- ![]() |
| Posted by hansmex at Nov 5, 2013, 9:34:21 AM |
Re: Can I customize the render settings Emmanuel, Would it be possible to create a Q5 for better rendering, or use Q4 for this? I tried several times to make a "bat"-file to have better results, but I don't succeed in getting it to work. If that's not possible, could someone make a small file that I can use, without me having to program anything? Hans ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by sree.arun.kr at Nov 5, 2013, 6:16:31 PM |
Re: Can I customize the render settingsHans download this file which has default settings http://www.mediafire.com/?9vmlx54x3zv90nh Then copy, paste to the location "C:\Program Files\Sweet Home 3D\SweetHome3D.exe" or the location where the "SweetHome3D.exe" located. & Here is the description for the commands http://www.mediafire.com/?1hbx7495ki2iu7y Edit the values or delete the lines if you want to customize. Then save SweetHome3D.l4j.ini & start application "SweetHome3D.exe" Improper or null value makes application crash then delete SweetHome3D.l4j.ini from the directory To see Available Graphics memory Go to Win > Start > Run (or press Win-key+R),then type "DxDiag" & click display tab > Total memory= Memory Values must be a multiple of 32. Here is the file I uses to Exterior rendering http://www.mediafire.com/?76y5jukvyqthgkl Sorry for my bad .English. ![]() ---------------------------------------- ![]() |
| Posted by hansmex at Nov 5, 2013, 8:15:56 PM |
Re: Can I customize the render settings Sree, Thanks for the information. I use a PC with Ubuntu (Linux), not Windows. As far as I can see, there are no *.ini files on my computer, and I really don't know what to do with those files. I start SH3D by double-clicking a file called SweetHome3D (881 bytes). I have tried to modify that file, but without succes. Hans ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by Puybaret at Nov 6, 2013, 3:37:19 PM |
Re: Can I customize the render settings Hans, it's really not complicated: simply add the -D... parameters one by one after exec "$PROGRAM_DIR"/jre1.6.0_45/bin/java---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by hansmex at Nov 6, 2013, 5:33:03 PM |
Re: Can I customize the render settings Emmanuel, I finally got it to work. I tried a few months ago, but I must have done something wrong. The "Optimized settings" work OK under Q3 and Q4. The "Default" settings work OK under Q3 and Q4. When I insert the settings given as "High settings", it works OK under Q3, but under Q4 I get immediately a black picture. No calculation done. (Same file, same everything) Best results always were obtained with Q3. Q4 consistently gives a lot of "speckling". (The infamous white artefacts) My test renders were 1200x900 pixels, and the slowest finished in about 3 minutes on my quad core computer. Seen (1) the rather large quality improvement and (2) the fact that increasingly people will use faster computers, maybe it is time to re-think the quality settings. My suggestion would be something like this: Q1 = current Q1 or Q2 Q2 = current Q3 or something similar Q3 = "default" or "optimized" settings mentioned above (or something similar) Q4 = Super high quality settings, lots of mirroring, ray tracing, bouncing, or whatever other settings you can think of, for a maximum result. The tool tips for these settings could explain that Q1 is for older, slower computers, Q2 is for a better quality image, maybe duo core, Q3 is high quality, preferably quad core, etc. This way you offer a greater flexibility without the need for lots of programming. Hans ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
Current timezone is GMT Sep 19, 2026, 6:01:05 PM |
