Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Problems because of low memory |
| Print at Sep 19, 2026, 11:16:31 PM | View all posts in this thread on one page |
| Posted by pabloyepes at Oct 3, 2013, 5:17:41 PM |
Problems because of low memory I think I am pushing the limits of SweetHome. I have a 22,000 sq ft building with 3 floors and roofs. When tyring to take a photo with very high resolution, SW complains that memory is not enough after a while. I wonder if that problem could be solved by recompiling the program with a higher memory allocation. Would that be something "simple" to do? Thank you |
| Posted by Puybaret at Oct 3, 2013, 5:22:39 PM |
Re: Problems because of low memory There are simpler solutions. Look at the FAQ How can I adjust the memory used by Sweet Home 3D? and eventually this message. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by pabloyepes at Oct 3, 2013, 8:39:54 PM |
Re: Problems because of low memory Thanks a lot. That did it. Now also the rendering seems to run faster |
Current timezone is GMT Sep 19, 2026, 11:16:31 PM |
