Print at Aug 22, 2026, 5:18:33 PM View all posts in this thread on one page
Posted by oren32 at Aug 25, 2013, 2:44:31 PM
Undo + Dragging
I downloaded the program. When I use it, I have things that don't work there, although they do work while using the program from the website. Two of the things are:
1. There is no possibility for Undo - It just doesn't exist. So i can't use Ctrl-Z at all
2. I can't drag furniture into the drawing. I can press Ctrl-Shitf-F, but then they appear always in a certain place in the drawing (From there it is possible to drag them of course).
Does anyone know how to make those things work?
Thanks
Oren
Posted by hansmex at Aug 25, 2013, 4:01:02 PM
Re: Undo + Dragging
SH3D does have an Undo and a Redo button, and it should be possible to drag a model into the 2D drawing window.
If your version of SH3D doesn't provide these functions, delete it and re-install it.
In case that doesn't solve the problem, please, provide more information on your system.
Posted by oren32 at Aug 26, 2013, 1:43:12 PM
Re: Undo + Dragging
Hi, Thanks
Sweet home 3d doesn't appear in the control panel at all (I have windows 7). How do I delete it?
Thanks
Posted by hal9000 at Aug 26, 2013, 1:48:55 PM
Re: Undo + Dragging
I have W7 and I have SH3D 4.1 in my "programs and features" list. How did you install it?
Posted by hansmex at Aug 26, 2013, 1:50:07 PM
Re: Undo + Dragging
Did you read
How can I uninstall Sweet Home 3D?
in the FAQ ?
Posted by oren32 at Aug 26, 2013, 2:22:51 PM
Re: Undo + Dragging
Yes I did. Sweet home 3d doesn't appear in my "programs and features" list.
Any ideas what to do?
Thanks
Posted by hansmex at Aug 26, 2013, 2:46:38 PM
Re: Undo + Dragging
I don't know. It's a long time ago since I last used Windows.
Posted by hal9000 at Aug 26, 2013, 2:58:31 PM
Re: Undo + Dragging
Look at the SH3D shortcut properties to find the folder where it has been installed, then go an delete that folder. In addition, as prevously pointed by Hans, look at the FAQ to see what other folders may be using SH3D to store data or configuration files and delete them too.
Finally download the latest SH3D version INSTALLER for Windows and install it.
Posted by oren32 at Aug 26, 2013, 3:19:13 PM
Re: Undo + Dragging
Ok, Thanks a lot. I don't have time right now, but I'll make sure I'll do all that later
