Print at Sep 6, 2026, 11:41:13 AM
Posted by RogerTE at Jul 11, 2013, 1:58:16 PM
New wall match existing sloping wall
This might not be easy to explain, but I have created an industrial style building design, approx 42m x 22m with eaves height of 5.2m rising to 6.5m at ridge along the 22mm walls.
So far so good. smile
Now I need to create a 15m long extension, by extending one of the, 5.2m high, 42m side walls. However this extension is only 8m wide. It needs to be ridged, continuing the existing roof line.
I am finding it difficult to match the height where the extension ridge (4m from side wall) should be.
Is there any easy way to do this rather than keep editing the end dimensions of the split 8m wall? confused
Thanks
Posted by hansmex at Jul 11, 2013, 3:56:54 PM
Re: New wall match existing sloping wall
A picture is worth a thousand words....
Posted by RogerTE at Jul 12, 2013, 12:48:27 AM
Sorry, took some time to produce something.
Sketchup drawing:
The main building already exists, just need to add the smaller extension.
What is causing a problem is accurately determining height of extension ridge to match with existing roof.
Hope that makes sense!
Thanks
Roger
Posted by hansmex at Jul 12, 2013, 6:33:47 AM
Roger,
Sorry, if I seem a bit slow... but WHERE should the extension come? Can you at least draw the walls?
