Total posts in this thread: 4
Previous Thread This topic has been viewed 3474 times and has 3 replies Next Thread
RogerTE
New wall match existing sloping wall
This might not be easy to explain, but I have created an industrial style building design, approx 42m x 22m with eaves height of 5.2m rising to 6.5m at ridge along the 22mm walls.
So far so good. smile
Now I need to create a 15m long extension, by extending one of the, 5.2m high, 42m side walls. However this extension is only 8m wide. It needs to be ridged, continuing the existing roof line.
I am finding it difficult to match the height where the extension ridge (4m from side wall) should be.
Is there any easy way to do this rather than keep editing the end dimensions of the split 8m wall? confused
Thanks
[Jul 11, 2013, 1:58:16 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: New wall match existing sloping wall
A picture is worth a thousand words....
[Jul 11, 2013, 3:56:54 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
RogerTE
Sorry, took some time to produce something.
Sketchup drawing:
The main building already exists, just need to add the smaller extension.
What is causing a problem is accurately determining height of extension ridge to match with existing roof.
Hope that makes sense!
Thanks
Roger
[Jul 12, 2013, 12:48:27 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Roger,
Sorry, if I seem a bit slow... but WHERE should the extension come? Can you at least draw the walls?
[Jul 12, 2013, 6:33:47 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
