Print at Aug 21, 2026, 5:12:46 AM
Posted by hal9000 at May 30, 2013, 7:28:56 PM
Existing menus localization
I'm trying to put a plugin's option inside an existing SH3D menu, but since the menu names change depending on the current language I don't want to use for example "Plan", because if I do so then on my SH3D on Spanish I'll have the actual "Plano" menu (which is the Spanish translation for "Plan") with all the options and then a second "Plan" menu with only my plugin's option.
So, is there some way to get at runtime the localized strings for the menu names? That way the option will appear on the intended menu regardless of the current language.
Posted by hal9000 at May 31, 2013, 12:25:22 PM
Re: Existing menus localization
I've seen HomeView.ActionType for the menu options, but HomePane.MenuActionType is declared as private. sad
Posted by Puybaret at May 31, 2013, 12:31:51 PM
Did you have a look at the section about localization at the end of the Plug-in developer's guide?
If you don't want to bother too much about this, you can use the Tools menu too.
Posted by hal9000 at May 31, 2013, 12:52:47 PM
Yes I did. But that allows me to localize the strings I use on my plugin, not to get the existing localized strings on the application.
Of course if I want to put my plugin option on the "3D View" menu, for example, I can just get all the translations for "3D View" from SH3D source and put them on my plugin. But the problem is that if in the future the localized string for "3D View" on some language changes, then on that language there will be two "3D View" menus, one with my localization (which coincides with the former official localization before the supposed change) and one with the new official localization.
The same problem will occur if a new language is added which is not included on the plugin: duplicated menu.
If there is a way to get the localized string at runtime then the option will always be displayed on the correct menu. If currently there is not a way to retrieve these strings, I think it's a good addition for a future release to prevent these menu duplications by the plugins.
Posted by hal9000 at May 31, 2013, 1:21:31 PM
blushing blushing blushing blushing blushing blushing blushing
OK, forget what I said... I centered on the PluginAction constructors and overlooked the ResourceBundle part.
If somebody is interested, you can retrieve the name of a menu, lets say the "3D view" menu, like this:
ResourceBundle.getBundle("com.eteks.sweethome3d.swing.package").getString("HomePane.VIEW_3D_MENU.Name")
This is still not at runtime, but at least with this approach you don't need to copy to your plugin all the translations of the existing menus you want to use.
Thanks Emmanuel.
Posted by hal9000 at May 31, 2013, 3:06:51 PM
By the way, can a plugin create a new submenu to group actions, or can only create actions on a first level menu?
Posted by Puybaret at May 31, 2013, 3:46:45 PM
You can retrieve the resource with getLocalizedString method found in user preferences too:
getUserPreferences().getLocalizedString(HomePane.class, "VIEW_3D_MENU.Name")
There's no way to create a sub menu at this moment.
Posted by hal9000 at May 31, 2013, 4:22:25 PM
Good! That seems a cleaner way to do it.
Thanks.
Posted by hal9000 at Jun 14, 2013, 4:51:05 PM
Now I have a related problem.
If I change the application language the plugin menu entry remains unchanged until I close and the open the application again. Is there some way to detect the language change so I can update the option name?
Posted by Puybaret at Jun 14, 2013, 5:48:13 PM
Listen to UserPreferences.Property.LANGUAGE property changes, and be sure to use in the listener a weak reference to your plugin to avoid memory leaks (UserPreferences instance is some kind of global variable). See ResourceAction.LanguageChangeListener for an example.
