Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Noisy reflection |
| Print at Sep 6, 2026, 10:46:08 AM | View all posts in this thread on one page |
| Posted by Eo at May 30, 2013, 2:50:51 PM |
Noisy reflection I have a question about the reflection on the wall. There is a wall and an object. Wall - glossy colored ceramic tile, without figures. Tiles should be self-colored and smooth, but a reflection on the wall looks like a single points of light, or as noise. I want to get a smooth reflection. How do I make a reflection without noise? Sorry for my English. Example: http://www.mediafire.com/view/sp7rc8azzx7aed6/03_copy.png Used texture: http://www.mediafire.com/view/6i16iuwuz1jojbo/3.png |
| Posted by Puybaret at May 30, 2013, 4:33:10 PM |
Re: Noisy reflection The easiest way to reduce noise is to create a twice (or more) larger image and reduced it once the image is computed with an image software. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Eo at May 30, 2013, 7:19:57 PM |
Re: Noisy reflection The twice larger image and then reduced looks much better. Thank you. For comparison - original: a twice larger image and reduced: ![]() |
| Posted by hal9000 at May 31, 2013, 12:01:45 AM |
Re: Noisy reflection Hmm... that may serve as a workaround, but when you're rendering an HD image which takes several hours to complete, the last thing you want is to multiply the rendering time by 4. ![]() ---------------------------------------- If a long walk every day were healthy, mailmen would be immortal. ![]() |
| Posted by Puybaret at May 31, 2013, 12:28:36 AM |
Re: Noisy reflection As said before, it was the easiest way. The other way would be to increase antialiasing with the following parameter passed to the JVM (see also this message): -Dcom.eteks.sweethome3d.j3d.PhotoRenderer.highQuality.antiAliasing.max=3Rendering will go slower but not as much as computing a larger image. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 6, 2026, 10:46:08 AM |
