Print at Aug 22, 2026, 6:29:27 PM
Posted by aurelie.faticati at May 24, 2013, 1:36:59 AM
sweet Home doesn't start
Hi, I just bought the surface Windows 8 pro...
I installed the program, but it won't start propertly, it stops in the middle of starting. Does anyone has a problem like me?
I tried to restart my surface countless time, I installed the new java, I desintalled et reinstalled three time the program :(
Does someone has a solution?
Thanks
Posted by danser01 at May 24, 2013, 2:47:14 PM
Re: sweet Home doesn't start
I am unable to load the program successfully as well. I get the splashscreen come up, but it just sits there and doesn't do anything.
I'm on Windows 7 Pro 64bit with Java 7 and local admin rights.
I have uninstalled, CClean'd my machine and tried again with same results.
I can see the SweetHome3D.exe*32 process running in my Task Manager, but it doesn't show up in the Applications list.
Any ideas?
Posted by Puybaret at May 24, 2013, 3:42:36 PM
Did you both try the recommendations proposed in the FAQ?
Posted by danser01 at May 24, 2013, 5:16:00 PM
Reinstalled graphics drivers and now works - thanks!
Posted by aurelie.faticati at May 25, 2013, 4:44:53 PM
I just reinstalled my graphic driver and now works :D
Thanks everybody!
Posted by Puybaret at Jun 3, 2013, 4:53:37 PM
Aurélie, would you be kind enough to tell us how Sweet Home 3D work on a Surface Windows 8 pro computer? Is the user interface still usable with a small screen? Is it sustainable to draw walls and rooms with the finger or the included pen? Are performances correct?
