Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: vertical diagonals |
| Print at Sep 6, 2026, 10:46:05 AM | View all posts in this thread on one page |
| Posted by oldgreybeardloon at May 7, 2013, 3:47:55 AM |
vertical diagonals Hi all Is it possible to draw vertical diagonals, ie., frame crossbracing? If not specifically, then perhaps a sneaky workaround? |
| Posted by Puybaret at May 7, 2013, 1:22:50 PM |
Re: vertical diagonals The workaround would be to use a box or a cylinder found in the miscellaneous category, resize it to make it look like a beam, export it with the 3D view > Export at OBJ format menu item, then import the export file with the Furniture > Import furniture menu item, and fine tune its orientation at the second step of the furniture import wizard using the Shift key + arrow buttons. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by oldgreybeardloon at May 8, 2013, 5:39:06 AM |
Re: vertical diagonals Thank you Emmanuel, Magic! |
Current timezone is GMT Sep 6, 2026, 10:46:05 AM |
