Print at Sep 6, 2026, 11:23:52 AM
Posted by oldgreybeardloon at May 7, 2013, 3:47:55 AM
vertical diagonals
Hi all
Is it possible to draw vertical diagonals, ie., frame crossbracing?
If not specifically, then perhaps a sneaky workaround?
Posted by Puybaret at May 7, 2013, 1:22:50 PM
Re: vertical diagonals
The workaround would be to use a box or a cylinder found in the miscellaneous category, resize it to make it look like a beam, export it with the 3D view > Export at OBJ format menu item, then import the export file with the Furniture > Import furniture menu item, and fine tune its orientation at the second step of the furniture import wizard using the Shift key + arrow buttons.
Posted by oldgreybeardloon at May 8, 2013, 5:39:06 AM
Thank you Emmanuel, Magic!
